Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
How to turn off jacuzzi jets - Jacuzzi - Bathtub - Alcove - Navona - R105917
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
I've got no water coming thru the side jets in my pool, even though water is pouring through the jacuzzi jets. The jacuzzi is all part of the pool.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Sep 27, 2010 | AO Smith 1 hp Swimming Pool - Jet / Well...
Jacuzzi jets smell like rotten eggs when turned on.
Need to run some cleaner through jets to clean out old water and mildew.
May 09, 2010 | Home
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Laser II: Problem with the Heater/filter setting. The jets come on when it's on this setting. When I turn it to Filter setting it's fine..when I turn it off the jets come back on What gives?
The jets will run while in the filtration / heating mode. If the spa is in the middle of the filtration cycle, the jets will stay on until the cycle time runs out. So, if the spa jets are on during this time, they are on for the full duration, 2-6 hours every 12. You can cycle the jet button to high, but when you try to turn them off, they will just go back on low.
Jan 23, 2010 | Jacuzzi Cyget In Ground Pool Pumps
One out of 5 jacuzzi outlet works with force, the other do not even when the air flow is totally open.
try turning off the 5 previous jets in order to see if there is enough water flow to get to the last jet.
Feb 17, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Trash come out of jets
Sounds like the hoses to the jets are the pump are breaking down and pieces coming off. Replace the bad hoze(s).
Feb 01, 2009 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
54 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
