Question about Amerock 3 Ring Knobs - BP1586
The thread on the screw has gone
I need to remove the knob without damaging the door
Anonymous
F the screw head is stripped you will have to replace the knob and screw. Try holding the screw head and turn the handle is its a single knob. Otherwise use a hacksaw or dremel tool and cut about 3/8" away from the door surface, once you cut through you can use a small punch to push the screw through the door then pliers to pull it out. Alternately you could use a dremel tool and carefully grind the head of the screw down until you can brake the head off and pull the handle and screw out through the front.
Posted on Aug 11, 2014
1 Related Answer
Anonymous
  • 187 Answers
SOURCE: Broken door knob, cannot enter room
I know I don't need to mention that knobs with an emergency release inside the house are wonderful things. Many function by sliding a nail into a hole in the middle of the door knob, others use the push/turn technique.
First thing to try is pushing the door knob in and then pulling it out while turning it as far as you can in both directions. If a part is worn out or misaligned, sometimes this is just enough to do the trick. If that doesn't work:
Now that the pins are out of the hinges, try working with another person if you can. Don't concentrate all of your efforts on the latch if you haven't been able to access it because of the moldings. Hinges get sticky and may need a good nudge.
Have one person push the door up from the bottom or top with a small pry bar or large screw driver. While this is happening, watch the hinges. They fit together like a jig saw puzzle, there should be play and they will loosen up a bit now. Now you will have an idea of the best way to try this.
Remember, the hinge side is no longer attached, so caution is in order. If you are working from a side without molding, pull out from the bottom and/or top while lifting gently with the pry bar. You can sometimes use a fulcrum and step on the pry bar if you are alone.
If molding is blocking your side, try pushing the hinge side inward. If that doesn't work, Using the pry bar, go to the bottom corner on the door knob side and tilt the door toward the opposite corner as much as possible.
If you can, jam something as sturdy as possible (screwdrivers)above and below where the latch is. With another screwdriver of tool, push directly into the latch and push the handle of what you are using in the direction opposite the door. Give it a good yank.
Try to be observant and creative while doing this. You are looking to try and squeeze out just a little more space. Use any area where you see play. Underneath, along side, up top, where ever.
There will undoubted be some damage to the wood or paint, remove the molding piece alongside the latch. It will be affordable to replace if you are a diy person.
For the others that commented, parts inside get worn and as mentioned above, the shaft has to be aligned correctly. If not, you run into problems like the latch not fully engaging.
Cutting the knob off will be a bit difficult. Even when that is done, it may be difficult to remove the latch and metal burrs are razor sharp. I think I would call a handyman before attempting that. Good luck all.
Posted on Nov 22, 2009
I understand that my Moen kitchen faucet is leaking and that it probably needs new orings but I cannot unscrew the top to get at it. What can I do to loosen it?
Usually I would stop here and give up. Time you will spend will not be worth your trouble. A new faucet is a better solution. But you asked a question and I respect that. If I wanted to pull the knob off and the screw was damaged or frozen. I would drill out the head of the screw. Once the head is gone, the knob should slip off the splines. Now check if you will need to replace the valve or rebuild it. If the valve can be rebuilt. You will decide to either leave the broken screw alone or remove it before rebuilding it. I would try to heat up the screw and splined collar with a propane torch and try to dissolve the corrosion trapped between the threads. Then use either small vise grips or adjustable pliers to see if I can work out the broken screw, without damaging the splines.
Sep 21, 2018 | Moen Plumbing
Any ideas on how to remove a stripped screw from lawn mower, Briggs and Stratton, top plate, there are 3 screws and one is stripped not allowing the cover to come off
By stripped, do you mean the head is stripped, or are the threads stripped.
Head stripped = Damaged Screw Extractor Drill Bits 4 in 1 Bolt Extractor Set Easy Out...
Stripped threads = You need to "drill off" the head of the stripped screw. Get a sharp drill bit that is at least twice the size of the threads. Drill into the screw head until the entire head is gone or can be removed..Once the entire head is gone, you should be able to remove the cover..once the cover is off, you should be able to remove the screw with vise grips or other suitable tools.
Jul 08, 2017 | Briggs Garden
The screws that hold our doorknob don't hold the knob anymore.They have loose threads and the screws are already too short that they don't hold the knob anymore. Everytime we turn the knob and pull it to...
Get a tap and re-tap the threads to the next screw size up. Then get matching setscrews. You could put a bit of Loctite on the new screws to keep them secure. Use a FINE thread tap so you get more threads in the knob.
Another solution is to clean and fill old screw hole with metal filled epoxy. Let is dry and re-drill and re-tap to original thread. Devcon makes a filled epoxy as well as JB Weld.
Mar 18, 2011 | Garden
If I do not have the key, How do I remove the exterior door know on an emtek lock. I was able to remove the inside door knob with a set screw. I have a rectangular plate on the inside with no visible...
There should be a pin set on the outer knob as well. if not the inner knob after it has been removed should thread off, you may need to turn opposite thread.
Oct 02, 2010 | Top Knobs M826 Door Pull
How do I remove the inside door panel of a 2001 AU11 Ford Fairmont to get at the manual door cable?
Standard Trim Disconnect the remote rod-to-lock knob assembly prior to lifting off the housing plate, to avoid possible damage to the lock knob assembly.
  1. Remove the inside door handles by unfastening the retaining screws.
  2. Remove the armrest. Tag and disconnect all electrical connectors.
  3. Remove the mirror remote control bezel nut and bezel.
Before you proceed to the next step, carefully inspect the door panel to make sure that all the retaining screws have been removed.
  1. Using a wooden spatula or panel puller (available at most automotive parts stores), pry around the trim panel putting pressure at the door trim clips. NEVER PRY BETWEEN THE CLIPS.
  2. Installation is the reverse of removal. When installing the trim panel, align the clips in the panel with the holes in the door, then apply pressure on the panel over the clip until the clip snaps into place.
Deluxe Trim Disconnect the remote rod-to-lock knob assembly prior to lifting off the housing plate, to avoid possible damage to the lock knob assembly.
  1. Disconnect the negative battery cable.
  2. Remove the screws from the door handle cup.
  3. If the car has an armrest courtesy lamp(s), remove the lens, then remove the bulb and wiring. Remove the pull cup.
  4. Reach through the pull cup opening and disconnect the remote lock rod from the lock knob.
  5. Remove the retaining screw and the remote mirror bezel nut from the power window regulator housing switch plate. Raise the plate to expose the window switch and power door lock switch and disconnect them.
  6. Remove the retaining screws from the armrest assembly.
Before proceeding to the next step, carefully inspect the door panel and make sure all the retaining screws have been removed.
  1. Using a wooden spatula or a panel puller (available at most automotive parts stores), pry around the trim panel putting pressure at the door trim clips. NEVER PRY BETWEEN THE CLIPS.
  2. Disconnect the speaker wiring and lift off the panel.
  3. Installation is the reverse of removal. When installing the trim panel, align the clips in the panel with the holes in the door, then apply pressure on the panel over the clip until the clip snaps into place.
May 06, 2010 | 1983 Ford Fairmont
I have old glass door knobs and the shafts are stripped and also need the set screws. Where can I find this parts?
Probably all you need are the set screws to lock them in place. They are sometimes allen head set screws, though some older ones will have a flat head screw like those shown here. In either case, a good hardware store with many drawers of small specialty screws should be able to set you up with what you need. Take a knob or two with you and make sure to get a screw with the correct size diameter and thread pitch, so you don't strip out the threads in the knob. (You can check the knob using longer screws to determine the correct dimensions, then find a set screw that matches.)
You could also try a specialty catalog along the lines of Van ****'s restorers, click here, or a specialty hardware supplier online like the one here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 08, 2009 | Hardware & Accessories
I have a Breville ESP6 Espresso Machine which needs a new steamer wand. The seal on the screw in part at end has gone and the thread is gone too. Water spurts out between the wand and the screw in knob -...
The wand is relatively easy to remove. Thing is whether you have the right tools. If you can find stubby phillips and flat screw drivers, the job will be much easier.
You first have to remove the trim that surrounds the pod and where it covers part of the wand.
The wand is held down by a flat-headed short screw. It might take a few tries to remove this screw due to calcification over the years. Once removed, the wand should just slight out. Check if the o-rings need to be replaced as well.
Mar 05, 2009 | Breville ESP8XL Espresso Machine
Clutch Release Problem
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
sewman7
Jan 16, 2009 | Brother Sewing Machines
Stuck Door Knob with No Access!
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Jan 10, 2009 | Hardware & Accessories
Amerock 3 Ring Knobs - BP1586 Logo
91 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
