Question about Prima C2012 TV
What is the BPL 5137RU TV power supply STR number?
LG tv str w6754 glows and short. power supply is not working?
Replace that STR. Before replacing, check all the related component/s at the SMPS section [HOT] side. any one damaged component will make the replaced STR to fail. If you wish to get some details; check the site linked here. Pull up older posts.
SMPS Circuit diagrams [STRW6754] of many popular brand TVs and other devices are given.
Search the site by type in the "BRAND NAME" or the STR number; of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 04, 2016 | LG Televison & Video
Is str f6707 the right power supply for daewoo tv model DTU-14d3
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Schematics to power supply regulator section to many popular brand TVs are given. Search the site with the STR number to your TV.
Dec 31, 2014 | Daewoo Televison & Video
My china crt tv uses str w 6554 but has a fault in power when you fuse it with a bulb it blick the bulb bright.
Check the entire circuit around the STR for any faulty component/s; especially to used Zener diodes. You should check each component in the power regulator section circuit, before replacing an other STR. Any of the faulty components at its circuit, might damage the new STR too. Be care.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Power supply regulator section circuits to some popular brand TVs are given. Search the site by the number of STR, used at your TV.
Jul 20, 2014 | Televison & Video
What str used in sharp tv
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/Pull up older posts. Power supply schematics to many popular brand TVs are given. Sharp itself uses many STRs. You can compare the schematics and can get the details.
Dec 31, 2013 | Sharp Televison & Video
What is the number of str ic,regulator power supply a 14 inches sharp tv. model primo sharp tv 14 inches
Try the site linked here. It has schematics of power supply section to many popular brand TVs. http://electronicshelponline.blogspot.com/ Hopes it will help you to check out the number of the STR.
Dec 18, 2013 | Televison & Video
BPL TV NOT STARTING
if no any power indicator that light or even blinking, the first place to be check will be the power supply section you must check weather the fuse is blown.if the fuse is blown before you replaced with new one you need to check other component in the power supply section like transistor and diode. so this case need proper trouble shooting, if you think you don't have enough idea in any electronic repair just leave it to the trained tv technician.
Aug 12, 2012 | Televison & Video
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My videocon tv 5137RU service code on my remote
Hai !...
Ther was a nothing problem to worried.
I want my old Vediocon (Model -5302R) Tv's
Remote model number. Because i lost my remote.
I want the solution. Pls help me.
Thank you.
Jan 11, 2009 | Televison & Video
Prima C2012 TV Logo
71 people viewed this question
Top Prima Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
