Question about Samsung LE Televison & Video
SOURCE: my samsung dlp tv model hl-p5063 w cuts off multiple times while playing
Hi, I had the same problem on my Samsung.
I removed the rear cover and cleaned the cooling fans, there were (2), it has worked fine ever since.
Be careful of course working with electrical boards.
Posted on Dec 01, 2007
SOURCE: I have a a insignia lcd tv model ns-27lcd turns off by itself
The problem is most likely the fuse connected to the power wires. You have to take apart the TV and follow the power wire to the fuse. Fuse number is T4AL/ 250v. It will be labeled above the fuse. We had the same problem. Also, check to see if the metal around the tops and bottoms of fuse are loose.
The way we fixed it was to wrap aluminum foil around the fuse and put it back in. It is only a temporary fix until we can get a fuse. Hope this helps.
Posted on Nov 26, 2009
SOURCE: Sony KDL46XBR switches itself off randomly light blinks red twice
Your power board got zapped you will need to replace it.
Posted on Dec 16, 2009
SOURCE: Insignia NS-LCD32 - 32" 720p Flat-Panel LCD Turns itself off, resets, then turns back on
It's haunted. You must appease the spirits with a virgin sacrifice.
Posted on Jan 15, 2010
SOURCE: Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Posted on Apr 10, 2010
Aug 24, 2014 | Samsung Televison & Video
May 13, 2011 | Samsung Televison & Video
Mar 08, 2011 | Televison & Video
Apr 23, 2010 | Televison & Video
Oct 03, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
May 04, 2009 | Televison & Video
Jan 20, 2008 | Sharp 32C-240 32" TV
Nov 10, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Sep 19, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
223 people viewed this question
