Delphi Roady2 SA10085 XM Radio Receiver with Car Kit Logo
A
Anonymous Posted on Jun 19, 2014
Xm car receiver - Delphi Roady2 SA10085 XM Radio Receiver with Car Kit
Change radio setup to scan frequency from evry 200khz to evry 50khz
  1. Radio ON, tune to the XM channel 0 and record the radio ID. The radio ID will be required for activation of the new receiver.
  2. Call XM radio to deactivate the faulty receiver and activate the new receiver.
    • US: 1-800-556-3600
    • Canada: 1-877-438-9677
  3. Park the vehicle outside in an area with an unobstructed view of the southern sky.
  4. Leave the vehicle outside with the ignition switch in the ACC position and the radio ON, tune to the XM channel 1 for 30 minutes to activate XM service.
  5. Once activated, the radio will receive the remaining XM channels.
  6. XM is trade mark
Sony CDX-GT320 FM / AM / XM Radio / Sirius Receiver missing sat option?
Check the connections between the head unit and the XM tuner. If the connections are good check for power and ground.
Cant get xm weather on garmin 740s
To receive XM weather or audio, the GPSMAP 740s requires a GXM 40 Smart Antenna with XM subscription.
The GXM 40 Smart Antenna (010-00730-00) is used to receive weather and audio service from XM satellite radio. For details on XM services please visit our XM webpage.
Once a GXM 40 Smart Antenna has been connected to the GPSMAP 640, the device can display the subscription information for the antenna.
From the Home Page in Boating mode:
  1. Select Configure
  2. Select System
  3. Select System Information
  4. Choose Weather Subscription
From the Home Page in Driving mode:
  1. Select Tools
  2. Select XM Services
  3. Select XM Radio
  4. Set the channel selector to channel 0
  5. Select Radio ID
The subscription information will now be displayed on the screen.
Roady XT XM Radio Receiver: how do I change the radio station i want my xm to ...
First of all find a clear fm stn. on your car radio.Go to xm radio and push menu until fm freq. shows up.Push sel and use up or down arrows until the freq. matches that on car radio. push select again to set it.
''No Receiver''
I have a 2008 Sonata with satellite radio issues also. Everytime it rains and I have to do any traveling in it, the storage box located in the trunk floods and shorts out the receiver,LIKE OVER THE WEEKEND!!. This will be the fourth replacement and they (Dealership)still cannot fix the problem.
The factory xm volume to low in 2006 corvette
Separate 'plug and play' XM radios, like the one pictured above, have a "MENU" setup, and you can adjust the "Audio Level" in that menu setting. See if you can access an XM menu. You can also ask your question over at XM411.com or XMfan.com; both are 'fan' websites.
Good luck - nice car too!
I don'tknow how to use the satellite radio...
Got this off the crutchfiel web site.
Item #700XMSON1 $129.98 This XM Direct 2 package includes everything you need to add XM Satellite Radio to your compatible Sony receiver: an XM Mini-Tuner, a CNP2000UC universal adapter, and a Sony connector cable. The Mini-Tuner connects to the universal adapter, then you use the connector cable to hook up the adapter to your Sony receiver.
Use your home computer to program the universal adapter for your Sony receiver — you can reprogram this adapter to work with another brand in the future. Once connected, you'll be able to change channels and see programming information on your stereo's display. You can also use the included XM Mini-Tuner with your XM-ready home receiver or in another vehicle with a compatible dock.
A computer running Windows XP and Internet Explorer is required. The unit is not compatible with Windows Vista.
Note: A subscription to XM is also required — learn about XM's programming. Satellite radio service is available only within Canada and the lower 48 states — not available in Hawaii or U.S. territories. Portable reception may vary by location. If you have questions about the proposed XM/SIRIUS merger, read the XM Customer Promise. To view this file, you will need the Adobe Acrobat PDF reader.
2answers
XM Radio Receiver
Go to www.walmart.com and type in the search box XM Radio. Walmart carries a XM Docking Station that is capatable with most units. FYI though XM has merged with Sirrus so XXM will still work but will soon be unbuyable.
1helpful
Pioneer AVIC N2 XM NavTraffic problem
Did you try to contact Pioneer and express the problem? May be you should check all of your XM tuner bus cable, XM antenna and power wires connection see if they became loose when you removed it last time.
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Top Delphi Audio Players & Recorders Experts
John
John
xxxxxx xxx
ExpressFiX
ExpressFiX
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
