Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
A
Anonymous Posted on Jun 19, 2014
Why sirius traffic not working?
My 2008 acura rl is not receiving sirius xm traffic. but the sirius radio works fine. its been 3 weeks now. several updates sent from sirius cust. svc. a new navi disc was put in still no traffic. acura dealer is bewildered too.
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jan 24, 2008
SOURCE: Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Anonymous
  • Posted on Mar 25, 2008
SOURCE: great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Anonymous
  • 8 Answers
  • Posted on Sep 08, 2008
SOURCE: xm will not work
i understand that you're only getting preview channels..and had the radio for almost 3 years....yes, they might be correct that your radio was broken already...but, have you ever asked them to refresh the signal into your radio? If you want you can do it online at www.refresh.xmradio.com all you to do is to key in your 8-digit radio i.d(can be found on ch. 0) then click submit...it'll give u the activation instructions...that u need to follow faithfully..if this won't work..i'll get back to you next week..Godbless!
Anonymous
  • 8 Answers
SOURCE: XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Anonymous
  • Posted on Sep 18, 2008
SOURCE: xm radio
buy an adapter with a filter on it the new ones dont have one (it is a little black cylinder just before you plug it in your xm)
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Can my sirius sportster 2 won't receive channel 210
Yep, new radio. The old Sirius radios won't go above 184 (most won't even get above 145) and the old XM radios won't go past 256, so to get the "Xtra" channels you want a new XM radio like the Onyx PLUS, or The XM Edge - both will give you not only all the regular channels, but an eXtra 20 channels or so that you can only get online or on a new 2.0 radio. Let me know how it works out for you. Regards, Engineer Scott
Why can't i get oprah on my sirius radio [email protected]
On Sirius radios, some programs require a subscription to the "Best of XM" and on some XM radios, you need a subscription to the "Best of Sirius" to get their programs. Call XM/Sirius and ask them, but I think that you have to pay extra for the "B.O.XM".
8helpful
9answers
My xm radio stopped working in a 2009 silverado.
Having the same problem in my 2009 Malibu. Have received 8 refresh signals and talked to the XM Techs 4 times. Taking car to dealership on Monday. Highly frustrated.
2helpful
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
2answers
Acura TL XM conversion to Sirius
You can get a Windshield Mounting kit and Sirius Unit and use the FM Frequency Modualator that is Built in and just not use the XM.
2answers
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
ExpressFiX
ExpressFiX
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
