This issue with your crock pot could be due to a malfunctioning thermal fuse or a problem with the heating element. The thermal fuse is a safety device that shuts off the power to the heating element if it becomes too hot. If the thermal fuse is faulty, it can cause the crock pot to shut off and turn on repeatedly.
It is also possible that there is an issue with the heating element itself. If the element is damaged or not functioning correctly, it may cause the crock pot to turn off and on intermittently.
To diagnose and fix the problem, it is recommended to take the crock pot to a professional appliance repair technician. They can test the thermal fuse and heating element to determine the cause of the issue and make the necessary repairs.
I would not use a slow cooker liner in an "instant pot." An" instant pot" is a type of pressure cooker which is electric. A "crock pot" (slow cooker) is not a pressure cooker. Note: The term "crock pot" is a trademark of Rival slow cookers. The Instant Pot name is trademarked by Instant Brands Inc.
You may be able to find a replacement liner for your model of electric pressure cooker.
If your electric pressure cooker is a brand name other than Instant Pot, you will need to search for a liner for the specific make and model of your electric pressure cooker.
There are several possible reasons why an Instant Pot might go into "burn" mode:
The pot is empty: The Instant Pot is designed to detect when the pot is empty and will go into "burn" mode to prevent the heating element from burning out.
The pot is too dry: If the pot is too dry, the Instant Pot may go into "burn" mode to prevent the food from burning.
The pot is too full: If the pot is too full, the Instant Pot may go into "burn" mode to prevent the food from boiling over and causing a mess.
The pot is dirty: If the pot is dirty, food particles or debris may be stuck to the bottom, which could cause the Instant Pot to go into "burn" mode.
The Instant Pot is malfunctioning: In rare cases, the Instant Pot may malfunction and go into "burn" mode even when it is not supposed to. If this occurs, you may need to contact the manufacturer for assistance.
If your Instant Pot goes into "burn" mode, it is important to follow the instructions in the manual for safely addressing the issue. This may involve removing the pot, allowing the Instant Pot to cool down, and cleaning the pot before attempting to use it again.
It comes with a one year limited warranty with proof of purchase, so if it is brand new, you should seek replacement under warranty if at all possible. See the information I could gather below, as a reminder that FIXYA volunteers are unpaid, and are usually not employed by the manufacturer of the products for which people are performing "do it yourself" repairs.
Trying to repair an appliance by yourself requires some technical skill, and a safety warning needs to be given to anyone, and if you are committed to using that model, and cannot get warranty replacment, you can also purchase an identical replacement model online using a set of several possible vendors at the link: https://marianoskitchen.com/instant-pot/
Some times it can be fix wit heat element.The manufacturer may have this part available to buy.Go to the website with your model number.Find it buy it install it do it your self and save.It may need some soldering done,or it may just unplug.Good Luck!
most slow cookers have a flexible element in the bottom of the cooker. the porcelain "pot" fits into the shell or outside of the cooker. heat rises so naturally the outside of the pot will heat up after the pot and anything in it heats up. (radiated heat) some have insulation around the inside of the shell to slow down the heat convection but will heat up eventually. that's why they all have phenolic handles. if they didn't heat up then would you need handles?
