Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
How to enter service mode to sony tv
Universal remote control codes
Posted by The Knight on
5 Related Answers
Anonymous
SOURCE: need a universal remote control code for sony dav-dz 100
1903 will work for most functions, but not the DVD player buttons.
Posted on Dec 26, 2007
Anonymous
SOURCE: Comcast On Demand Universal Remote Control
try code 10000
Posted on Oct 03, 2008
Anonymous
  • 24 Answers
SOURCE: code to enter service mode
Forget the service mode. The tv power supply regulator has probably failed.
Posted on Oct 08, 2008
Anonymous
  • 12 Answers
SOURCE: general electric Universal remote control codes
most of a companys manuals are online if you go to there web site.. they even have pictures of remotes if your not sure what model number it is and they will instruct you on how to enter it
Posted on Oct 16, 2008
Anonymous
SOURCE: tv remote codes
I have a Zenith universal remote that i want to program to a sony 27 inch Trinitron, what are the codes?
Posted on Nov 19, 2008
How can i program my vizio tv , to my sony home theater remote?
Make sure to hookup and power on all the Sony TV or other device you want to setup using Sony universal remote codes. next, make sure the batteries are working in the universal remote. Note down the Sony universal remote codes from the list provided. Nothing is more frustrating to find out that you have not hooked up or universal remote batteries are bad after spending your evening on trying to program Sony universal remote.
step1
Turn on the component to be programmed.
Step 2
On the remote control, press and hold the SET button until the SET indicator lights up.
Step 3
Press the appropriate component select button for the component being set up.
Step 4
Using the number pad, enter the component's manufacturer code. Note: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
Step 5
Press the ENTER button.Point the remote control at the component and press the POWER button.d out that you have not hooked up or universal remote batteries are bad after spending your evening on trying to program Sony universal remote
Sansui Chic Classic 250 TV
Before entering service mode, be sure that the entire button on the remote control will work properly, if anyone found inoperative, do not use it to enter the service mode. If it is a universal remote control; check it well. With most universal remote controls, sometimes, all the button functions might not work as it should be. If so, try to set it with another set-up code said for your device, and then make sure about its working. I strongly recommend you to use the original remote control to enter service mode.
This is because;
Suppose you have to enter the service mode to adjust certain parameter. You haven't made sure that all the function of the remote control will work properly with your set or not. After entering the service mode, as you know, limited buttons on the remote control will be active. For example, in service mode, channel Up, Channel Dn, Volume Up and Volume down, and the OK button, Power button and Numerical buttons are used to adjust the data parameter. After adjusting all these parameters; you have to come out from the service mode to Normal mode. Otherwise, you can't operate the set. Suppose, the service mode procedure tells you that, you should press the Power button on the remote control to Power Off the set, to come out from service mode to normal mode. Power down the set by its main power button won't make it to normal mode. If the power button on the remote conrol does not work, how can we come out from service mode to normal mode? In fact, you can't come out of service mode.
The most important thing to note is this. Before you attempt to enter the service mode option, read and understand all the instructions. Be sure that there is enough detail to Exit from the service mode. If it is not there, never enter the service mode. For some sets, there will be no Exit option. To such sets, Power it OFF by the main power switch will do the same. But you should make it sure by reading the instructions.
For your information, I've included some set-up codes too here, to check with your universal remote control, if the present set-up do not work with all the functions it supposed to be. Set-up a universal remote control is a trial and error procedure. You might have to check with many set-up codes, before you get a proper code to your remote control to work properly with your set. The included codes are the common codes works for your brand. If you wish to get more set-up codes and set-up procedure, visit the sites linked here.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
You can get more details by this site too.
http://electro-medical.blogspot.com/
After enter the site, just type in the brand name to your set; in the search box, at the top right of the display window; to get gathered the related pages that contains details. Please do not press the 'Enter' button, after type in the brand name into the search box. The search will start automatically, as you type in the brand name into the search box, and will list related pages.
Sony bravia KDL-46S4100 how to factory reset with no remote tv has no pictre or sound
Without a remote control, your can't select this function. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
To get more details about how to make it reset, check the site linked below. You have to enter the service mode to the TV; to get select its reset function. Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
2answers
Factory reset with universal remote
Are you talking about secret number or did you break the button that brings up the menu? It shouldn't be possible to lock out direct button entry. To clear your secret number:
http://s3.amazonaws.com/szmanuals/1673990ad2c5041f6d45ee373745c145
Page 30.
Cant put sylvania dwt1905 on game mode with rca universal remote
You can't select its game mode, with this remote control.
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here.
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Problema con control universal sony rm-vz220
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
1helpful
My universal vizio remote needs to be reset to my sony t.v. i have no clue on how to reset it and i dont have the code any more can you help me please?
Hello
Setup code for Sony TV with Vizio Universal remote control is [ 0000 ]
The reomote control is pre-programmed to work with all esisting Vizio TVs. If you want to set up it with Sony TV, do the following.
1. Manualy turn on the TV.
2. Press the [TV2] button on the remote control.
3. Press and Hold the Setup button until the LED light flashes twice.
4. Enter (0000) using the number buttons. If the code is accepted the LED flashes twice after the last digit is entered. If the LED does not flash, repeat steps 2 through 4 once again.
5. Point the remote control at the tV and press POWER button. The TV will turn OFF.
Other four digit codes to check for Sony TVs are: 0128/0013/0002/0071 & 0380.
If code [0000] does not respond with try other codes. Repeatsteps 2 through 4 once again after entering each code listed. The code listed with Vizio universal remote control with Sony TV is [ 0000 ].
OK.
1helpful
I have a RCA Universal control and a Sony TV but no codes
Press Code Search button Indicator light on.
Press TV button light blink.
Here some codes enter for Sony TV 002,218,099,166.
tries Every these codes the blink light should off.Off On button should work tv goes off or on .
that it u have it
8answers
Tv code
www.usersmanualguide.com/sony/remote_controls
Remote control code
That doesn't sound quite like the usual procedure for programming a universal feature on a remote. Should have to put the remote in TV mode, then press something to get it into programming mode, then put in the code for your particular TV.
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
