Question about Whirlpool Duet GHW9150P Front Load Washer
Hose into pressure switch on kenmore duet washer
Thomas Rush
    Scholar:
    New Friend:
  • 84 Answers
That's not only not a question, it's not even a complete sentence.
How about if you start with the statement of the problem you're having, and then ask your question? This is the technique most likely to get you useful responses.
Posted on Jun 22, 2014
  • GORDON'S APPLIANCE SERVICE
    So many people on here make it impossible to help them. It's like going to the doctor and saying "I don't feel well, what's wrong with me"? I gave up
Rocky Wright
    New Friend:
  • 81 Answers
What about it?if it has a break in it, it will over fill,if it is clogged up it will over fill.if cracked,replace.if clogged,blow back thru it from the pressure switch end,hope this helps.
Posted on Jun 20, 2014
travelbobgau
    New Friend:
    Problem Solver:
  • 6 Answers
The error code F35 is very common on these front load washers. F35 means that the pressure switch thinks the tub is overflowing with water. The fix is to replace the washers pressure switch. The pressure switch is located on the top of the washer. To access remove the three screws that anchor the top down. The pressure switch is held into position with a plastic clips. Pull the switch or use a flat head screw driver to remove. Depending on the serial break, the pressure switch may have several wires going to it or a wire harness with several wires going to just a single plug. Before you order and replace the washers pressure switch, make sure the hose that connects to it isn't clogged. Often times sediment will get clogged where the hose connects to the rear of the tub and F35 will appear on the washer LED screen. You can purchase Whirlpool Duet and Kenmore HE parts by entering your model number in the
2 Related Answers
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: f28 code on whirlpool duet washer. The door locks
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Posted on Sep 28, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washeer has f33 code
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]@@@
Duet doesn't stop filling with water
Sounds like hole in rubber hose feeding PRESSURE SWITCH or could be switch itself, check hose 1st hole allows air to escape thus not operating the pressure switch, which in turn activates then turns off Fill Valves Good luck
Oct 02, 2013 | Whirlpool Duet WFW9550 Washer
Tip
Upon removing the top cover from the DUET washer, I found the pressure switch...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “FH” error code.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please post back if you can't find the tech sheet and/or need further assistance.
on Jul 03, 2009 | Kenmore Elite 45986 Front Load Washer
I ordered and bought the control panel part for my kenmore elite front load washer but the washer is still not washing it's flashin FH
fh is a water problem,does it fill with water?....... FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1HSpZo0dW
Mar 23, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet flashes F 02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer troubleshooting: What does washer display code 'F35' mean?
This indicates that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. Here is a link to help with accessing the pressure switch also if you need diagrams or illustrations of your particular model.
Sep 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: error code f20?
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
After a time the small hose that comes from the pump area to the pressure switch located at the top of the machine can clog.
Unplug the machine.
Remove the top or the back of the washer.
Locate the pressure switch near the top of the washer. It is about 4 in round and has wires and a 1/4 inch black tube attached to it.Pull the tube from the switch and blow through the tube until clear.
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud error then f35 error on Whirlpool duet washer.....I disconnected already for 5 minutes and also checked the drain and its patent...what can I do?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 45986 Front Load Washer
F32 comes up when we just installed our new Whirlpool Duet Washer WFW9200SQ.
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer duet
check to see if the pressure switch hose is not clogged, it connects to the pressure switch , you have to take off the top to get to it remove the 1/4 inch hose from the switch and blow through it if it blows freely then the hose is not the issue, they are many issues that can cause this faullt code hope this is the problem
Apr 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
122 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
