Question about Moen & One Handle Tub & Shower Faucet
Why wont my pegasus 9200 one handle shower turn off
1 Related Answer
Anonymous
  • 195 Answers
SOURCE: moen shower handle keeps turning it wont come to a stop
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Posted on Apr 06, 2009
How to remove hanble on a shower valve pegasus 161 263
Looking at the spares page it seems that the handle is on a spline (possibly tapered ) and should be able to lever the handle off with a couple of thin screwdrivers
Pegasus replacement faucet and shower parts
Nov 11, 2017 | Home
How do I adjust water temperature on a Pegasus shower head?
Adjustment is usually on the valve assembly. Take off the big round trim ring and you will find the adjustment on the valve assembly or in the valve stem.
Oct 19, 2014 | Pegasus F1226700RBP 1100 Series Single...
Pegasus tub and shower thermostatic faucet handle stripped
Sep 24, 2012 | Pegasus Technologies Plumbing
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
Have a pegasus shower single valve ..cannot determine how to adjust the hot water to increase it. Have hot water in bathroom sink.... renting this place...owner has no clue. removed handle and all that is...
when it is sold the anti-scold is set at cold to protect the buyer -the piece with the groves on it is the stem their should be two plastic clips a red and blue that slid over it these clips are the adjustment -also give pegasus a call they have an 800 number to assist u or home depot the carry the brand
Nov 09, 2009 | Union Pegasus F1228100PBV Series 5000...
How to remove the cartridge from my pegasus shower/bath faucet. the instructions are not very good.
remove handle , unthread collar , same with chrome body base . make sure water is turned off from valve
Oct 18, 2009 | Union Pegasus F1228100PBV Series 5000...
Single handle shower valve.. can't get any hot
factory set is usally cold for safety. remove handle, then remove cover. you will see the mechanism, bunch of plastic teeth, set it up in the middle, then try it, repeat process till you get desired temp
Aug 01, 2009 | Home
Single handle pegasus kitchen faucet. No water pressure when turn
Kitchen faucet? Remove the internal parts and check for blockages.
Apr 05, 2009 | Pegasus Technologies Pegasus F1225100BN...
I can't get hot water from the pegasus shower valve
The antiscald device needs to be adjusted. It's behind the escucheon and determines the amount of hot water flow.
Jan 13, 2009 | Union Pegasus F1228100PBV Series 5000...
Moen & One Handle Tub & Shower Faucet  Logo
130 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
