A
Anonymous Posted on Jun 18, 2014
How to fix a yellow sensor error - Xante Ilumina Digital Color Press Printer
Jose Marrero
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Jun 23, 2014
Jose Marrero
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
1250
Points
5
Some of the question do not have complete info. Some of you guys want help on problem you have with your ilumina but your questions are not complete with info. When you talk about color be in mine that the ilumina has 4 drums 4 ink cartridges etc. You have to tell us what is the problem related to. Thank you!
Toshiba air conditioning unit not working RAS-13UKH-G
If the operation light is blinking, it means there is an error with the unit. The number of blinks can indicate what the error is.
Here are some common error codes for Toshiba air conditioning units:
  • Blinking once: Indoor unit room temperature sensor error
  • Blinking twice: Indoor unit coil outlet temperature sensor error
  • Blinking three times: Indoor unit coil inlet temperature sensor error
  • Blinking four times: Outdoor unit discharge temperature sensor error
  • Blinking five times: Outdoor unit suction temperature sensor error
  • Blinking six times: Indoor unit EEPROM error
  • Blinking seven times: Outdoor unit EEPROM error
  • Blinking eight times: Indoor unit remote control error
If you can determine the number of blinks, you can refer to the user manual to see what the error code means and what steps you can take to fix it. If you don't have the manual, you may be able to find it online or contact Toshiba customer support for assistance.
I have error code of SC361-2 for MPC3002, what shall do is because of the magenta pump error or drum unit TD sesnor problem, what shall do
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC3002&code=361-02
Quoting from link above:
Ricoh Aficio MPC3002 Error Code
Code
361-02
Description
TD sensor (Vt high) error 1: C
• The Vt value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 4.7V) with SP3-020-002 for twenty counts. • The [Vt - Vtref] value of the black, magenta, cyan, or yellow TD sensor exceeds the specified value (default: 5.0V) with SP3-020-001
Causes
• Black, magenta, cyan, or yellow TD sensor disconnected • Harness between TD sensor and PCDU defective • Defective TD sensor
Remedy
1. Check the black, magenta, cyan, or yellow TD sensor connector and harness between the TD sensor and PCDU for damage. 2. Check the drawer connector. 3. Replace the defective PCDU.
Cycle pauses after about 6 minutes. It doesn't want to spin. In test mode, I'm getting error code E46. With tumble test, motor only tumbles in one direction. With spin test, motor won't spin at...
From what I just read if the same model sounds like the motor sensor could be bad It says it should read around 118 ohms at the two yellow wires when disconnected at the board.
Not sure if the motor will have to be replaced if the sensor is bad
the inverter can also be the problem
Google GE front load washer won't spin or tumble for more
Canon iPF610 hardware error 03800500-2F2F and 03800500-2F30
03800500-2F2F/03800500-2F30 Head management sensor error
0014-0999
The head management sensor detected an ink discharge error.
A sensor sensitivity error was detected during head management sensor position adjustment.
Print head, head management sensor, or main controller PCB
1) Replace the print head.
2) Visual check
Remove foreign substances from the head management sensor if any.
3) Replace the head management sensor.
4) Cable continuity check
If continuity of the cable between the head management sensor and the main controller PCB is abnormal, replace
the cable.
5) Replace the main controller PCB
2answers
2answers
Hi. I get the error message Toner sensor error,
Did you try replacing the cartridge? It could be the cartridge itself. Also, on a lot of printers there is a software utility that allows you to clean the cartridge. You can find this out from your manufacturer manual. But I would suspect the cartridge itself. Good luck!
1helpful
We have a CL7000 which comes up with error message SC375 & SC387. What does these relate to.
sc 375= Vt error [Yellow] (toner density sensor error)
sc 387=Development gamma error Yellow
it looks like there is a problem with your yellow development unit.
it may not set in properly or needs to be replaced.
4helpful
2answers
54.15 error code
Error Code 54.XX
Control Panel Message: Printer Error
Description:
15 Yellow CPR sensor
Recommended Action: Turn the printer off and then on, and then check the following itmes
Check the connections. Replace the color-registration detection assembly.
Description: Printing cannot continue. There is a sensor malfunction.
XX Description
15 - Yellow toner remaining sensor (J1014 toner level sensor)
2answers
Z4mplus
try to move up the silver plate unther the print head.
this silver plate is the "print head open" and the media sensors.
SERVICE CALL 150:FATAL ERROR
Replace Toner and Drum clean everything and it should fix ur issue
Top Xante Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
