SOURCE: how to change the belt on a bissell powerbrush
Turn the machine OFF (O) and unplug from
the outlet. To check if the brush belt or
pump belt has broken, you will need a flat
head screwdriver. Insert the blade end into
the lower slot of the belt access door to
release the lower snap. If necessary, insert
the blade end into the upper slot to release
the upper snap.
Hope this helps.
Richard
SOURCE: My bissell Powerbrush cleaner quit working. The
found it from Tara put online in nov 2008 Thanks this is it
Had the same problem... although I don't have particularly hard water, the heater block corroded just enough to stop most of the flow after about 4 years. Disassemble the handle to get at the heater block (3 pairs of screws/bolts), remove the tubes with needle nose pliers, use a paper clip to knock out the corrosion on the front tube on the heater block, flush with a syringe to get rid of any other bits of corrosion (some extra plastic tubing connected to the back tube of the heater block helps here, and catch the water from the front tube to prevent water in the electronics...), reassemble (avoid disconnecting any wires...) and try it out. Worked for me! I REALLY have to thank the person who suggested this fix! THANKS!!!
I used regular pliers , phillips screwdriver , the pointed end of a compass and a turkey baster full of water to blast it out . You have to improvise . Take your time watch the little rubbers on the heater make sure its not hot . It was just the inlet gets pluged up in the heater . You have to take off the tools then its the bottom set of plastic not the handle . You can test by pushing the plunger at the top . You must take the handle off . Loosen the pieces it just came off for me then snaps back on . This is all it was for me , very simple . I am disabled and did it on a extra old carpet a little at a time over a few hours . For someone healthy its a hour job tops or less . Just be patient . God helps those who help themeslves and asks for patience .
SOURCE: I need instructions for the Bissell Big Green powerbrush
I recently did a Google search an owners manual for my inlaw's Bissell. I just googled your 168-3 and found a manual, hope it is the right one,
SOURCE: how do i put belts on a bissell powerbrush steam cleaner?
If this is the model i'm thinking of. Make sure the units unplugged from the wall. There should be about six phillips head screws to remove. The motor should now be exposed. This is a good time to clean up the inside of the unit. Use liquid wrench or WD-40 and lubricate any moving parts. Make sure the brush is in good shape some require you to rotate or flip the brush to even out the wear. I hope this has been helpful.... : )
SOURCE: powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
