Check the dump valve. Pull the wiring harness off of it to see if water stops dumping, if it dose not stop dumping then replace the valve. If if stops dumping water then you need to see what is causing power to be sent to dump valve this valve should not open until it gets a call from the control board when it goes into a harvest.
