mcdevito75 here, For larger print on your monitor screen, Left click VIEW at the top of your screen form any page, then click on TEXT size and if need be click on ZOOM for adjustments in letter size on your monitor. Hope this helps.
Try clicking on Window at the top of your page the click on ZOOM in the drop down box. This should maximize the screen to the monitor it is currently on,
Hold the Crtl button and press the - button and the page will get smaller, or go to View in the top of the browser and go to zoom and pick a smaller size.
When you rt click on the empty screen, go to personalize and then to display and make sure it is set to your screen resolution.
Have you tried adjusting the screen properties via Windows? maybe changing the resolution will fix it, and you can adjust the physical screen size too.
ur setting may be set to low resolution...
try doing this
go to Desktop/right click/properties/Settings/Screen Resolution/
What do u c...what's the resolution there...800x600...
if the slider(pointer) is active use it to increase it to say 1024x768, 1152x864, 1280x1024 etc.
use the correct resolution....as too much of resolution will make ur monitor un-viewable...
also try if ur monitor has some press button on them to make changes to the correct setting/zooming of the screen image...
on the monitor there are buttons normally with menu two other and a select button try going into the menu to size and position in there there should be a zoom selection try adjusting the zoom it should help
