SOURCE: lost manuel for teac ag d9100 reciever
you can download a manual for $9.99 from User-Manuals.com....I did this today and the manual is identical to the original it seems
SOURCE: Receiver keeps flashing "PROTECT"
The protect message indicates that a problem was detected in the last stage of the amplifier and that it has shutdown to prevent further damage. Usually this indicates that the output transistors have failed. Any shop that works on audio should be able to repair this. Expect a part cost in the $20-$40 range. Add in the local labor rate for the total repair cost.
Dan
SOURCE: how to remove the protect signal
Make sure that your input level are not too high. They will cause the an overload in the receiver and it will clip the circuit. This will continue until you lower the level of the input that you have on at that time.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
