Juki MO-644D Mechanical Sewing Machine Logo
A
Anonymous Posted on Jun 18, 2014
Bosch Ahs 7000 pro-t what makes the blades come off the gearbox?
Blades stopped cutting and opening up the machine found the blades had come off of their spigots
gbob59
Level 3:
  • Juki Master 3,063 Answers
  • Posted on Mar 27, 2015
gbob59
Juki Master
Level 3:
Answers
3063
Questions
Helped
704732
Points
10419
Attachment method is not correct. Owner's manual shoud tell you how to do it properly. No Owner's manual,
try manualslib.com if they have it.
or the MFG website.
2 Related Answers
Pete Alaniz
  • 13 Answers
  • Posted on Dec 15, 2008
SOURCE: I have a juki mo-3614
first, pull out the bvlades and make surte they are sharp. It could simply be that they are dull. Next, line tyhe bottom blade up level to the surface of the needle plate. The top blade should be adjusted to where it slices against the botom blade. You may have to experiment with the height adjustment on the top blade, assuming you have a suitable cutting edge.
Anonymous
  • 7 Answers
  • Posted on Jun 24, 2009
SOURCE: my blades won't cut, they seem to be rolling rather than cutting
check bottom blade,it should be flush with needle plate. when you turn hand wheel by hand the top knife should be even along the length of the bottom one .the top knige is held by a 7 or 8 mm screw [looking straight at you] slacken this ,turn wheel till knife come to bdc and push the top blade against the bottom one. however if the edges of the knives are shiny or worn ,it will never cut. you can buy them relativly cheaply [eastman staples huddersfield is main juki agent].
Replacing cutting blades on Bernette fun lock 007d
Normally, only one blade on a serger can be replaced by a user (assuming a replacement blade can be found). If both blades should be replaced, then a technician is strongly recommended since there are minute technical specifications required to make sure the blades are aligned properly.
1helpful
2answers
Why did it suddenly stop cutting?
Please provide the model of your machine.
Ok, it's a serger. Wondered why a sewing machine would be cutting unless it had the cut-n-sew accessory.
Most likely the blades are damaged or malfunctioning. Is the blade still moving when it is stitching? Is it just chomping away at the fabric but not cutting? If so, either or both blades need to be replaced. Consult your owner's manual. Usually only one blade can be installed without any technical knowledge. You can probably order the replacement blade and install it yourself. However, the other usually needs to be replaced by a knowledgeable technician because it requires some precision.
Has the blade stopped moving at all? If so, how long has it been since a thorough cleaning and oiling? Take it for service.
I replaced cutter blade on Elna PRO DC 5. New blade won't cut fabric. how do I adjust it?
All sergers have 2 blades. Just like scissors. Only 1 blade of scissor is sharp = not good cutting.
Feb 14, 2014 • Elna 1010
2answers
I need new blades
Pinocke1 3 thread no light. Will not cut
fabric may need new cutting blades top
and bottom. Need manual service and user.
My brother overlocker blades dont cut anymore and thet dont move either, please help!!!
if the blades don't cut then they need to be replaced,, and for the
blades not moving,, the machine need to be checked..
Pfaff embroidery cutting blade
do you want a cutting blade?? have found a site that has spare parts for Pfaff machines - hope this will help
Parts For Embroidery Machines ... Edge Cutter Attachments ... We carry new and used machines from Singer, Pfaff, Durkopp Adler and many more. ... We stock a wide range of rotary, drag and tangential blades, sign blade holders and blades, ... www.sloanmachinery.com/
If my machine is not cutting right do I need to replace both blades
not necesarily, can you see a knick in either of the two blades? use a magnifying glass and see if you can see any damage first.
Then try changing the fixed bottom blade only first, you may have got a replacment top blade in your accessory bag new with the machine.
The blades themselves are very high grade steel just like scissor blade so should last for quite a long time, provided they don't come into contact with a pin.
You can buy the bottom blade for your machine here http://www.sewingpartsonline.com/lower-knife-babylock-60544.aspx along with the top blade and other spares.
Also, remember to clean the blades of lint regularly and give them a wipe with a cloth moistened with a little clear sewing machine oil from time to time.
2helpful
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Serger blades do not cut.
For now, it works only satisfactorily:
I applied alcohol to further clean both blades,
dried and then oiled them. There seemed to be a slight gap between blades;
the fabric was dragged into the gap instead of being cut.
Jan 10, 2009 • Elna 1010
Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
