Question about Goodman CKL36AR36 Air Conditioner
Seems like the fan relay has stuck (Likely to be on the main indoor PC board) or if the machine was being used on heating mode, the indoor pipe sensor may have failed causing the fan to continue to run. Most air cons on heating mode, will keep the fan running for a few minutes after you switch off on heating mode to cool down the indoor unit before it turns off completely. The pipe sensor signals the main PC board to tell it that the unit has cooled down and can now turn off completely. If either of the above faults occur, the indoor fan will keep running all the time.
Posted on Jun 19, 2014
Testimonial: "I had already assumed the relay had failed , I then replaced the "Fan Control" circuit board, but that no effect on the problem."
Jun 13, 2018 | Heating & Cooling
May 29, 2016 | Mitsubishi Heating & Cooling
Apr 12, 2015 | Heating & Cooling
Feb 27, 2015 | Heating & Cooling
Nov 03, 2013 | Fujitsu ASU12RLS2 Wall Mounted Indoor Unit...
Aug 03, 2011 | Heating & Cooling
Jul 11, 2011 | Ruud Heating & Cooling
Jan 07, 2011 | Heating & Cooling
Jun 03, 2010 | Heating & Cooling
Jan 16, 2010 | Panasonic Heating & Cooling
103 people viewed this question
