Question about Sharp AR-5516s
My sharp machine ar 5516s is having problems giving error code l and 4 simulteniously what can i do
Posted by kefa babu on
5 Related Answers
Andy Bebb
  • 62 Answers
SOURCE: error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Posted on Jan 22, 2008
Anonymous
  • 126 Answers
SOURCE: Error Code F1-87 Finisher Trouble on Sharp AR-M350U+
It is a stapler rotation error. The stapling tray pressure arms become dull at the tips, so when the stapler attempts to move into position to make the staple it cannot move the guides out of the way.
First choice) Replace the (4) stapling tray pressure arms (LSTPP0357FCZZ). After you replace them you'll see that the tips get worn down, and wedge into place so that the black support plates cannot move out of the way of the stapler. The black plates look warped, but they aren't (I should say they always look like that).
They are fairly easy to get to. You do have to remove the finisher from the copier. Remove the front and rear covers. Open the right door. Pull the pins that retain the door. From there you'll see the arms. They can be changed with a little maneuvering.
2nd Choice) Clip overtight wire ties to the stapler rotation home position sensor.
3rd Choice) Shake down the stapler to its bottommost position (wherever it settles is fine). Adjust the flag that triggers the stapler home position sensor. If I remember correctly its the narrow **** in the flag.
Posted on Jan 28, 2009
Everett Lin
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
Anthony Karuku
  • 268 Answers
SOURCE: AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Posted on Mar 30, 2010
suhail aabed
  • 109 Answers
toner type error
replace the toner cartridge
Posted on Apr 08, 2010
can be the main motor locked if its l4-01 but if its l4-31 its fusing fan locked detected or l4-35 its PS fan locked detected
Jun 18, 2014 | Sharp AR-275 Copier
i hope its L4.If it is showing
L4 it means the main motor is locked(failing to move) Check all the moving parts including the drum unit, developer unit, main drive unit and fuser unit if they are moving freely. If they are moving freely change the main motor
Jun 18, 2014 | Sharp AR-5320 Black and White Copier
My sharp ar 5516s is showing error code L and 4 simultaniosly what can be the problem
Main motor lock,
Main-motor is unable to turn or has too much resistance, mlean main drive , and replace worn gears , if problem persists , check resistance on fuser-unit / developer-unit / OPC-unit
Jun 18, 2014 | Sharp Office Equipment & Supplies
Sharp AR5516 error code H4
Temperature error, use simulation mode 14 for reset the error , if not replace the thermistor, & use stabilizer to avoid problems due to power fluctuations.
Dec 04, 2012 | Sharp AR-5516s
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
F2 40 error code on Sharp 5516s copier
you must use ar-202 developer.205sd used for 5516 or 5520
May 23, 2010 | Sharp AR-5320 Black and White Copier
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5516s Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
