GE JASRM24912 Remote Control Logo
Question about GE JASRM24912 Remote Control
I NEED tOSHIBA 32a14 CODES?
Posted by PAT KIERNAN on
Toshiba 32a14 codes
It weighs [111] lbs
Codes to check are, 2086,2091,2004,2007. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
I have a toshiba 32a14 TV and an Auvio universal remote. I can get the remote to turn the TV on and off but I can't get it to change the input to the TV
Tv universal remote have it limted to it used and operations,only operate the basic only like power on/off and channels up/down also volume up/down that about it.The tv input video 1 or 2 for IN tv to used are tv personal funcstions only for the tv original remote control only have it functions for.Try the website Remotes.com to buy the tv original remote.
1helpful
It is a 32A14 model. power to house was cut off, electric people replaced phone poles. when power came back on tv wouldn't turn on, no red LED indicator light lit up, and it makes this chirping sound in...
The tv high voltage "H" horizontal transistor IC is dead.That "H" transistor IC sit out side outer wall of the FBT-the flyback transformer,that the big black block of a plastic,with a red wire with a cap hook up to the CRT-(tv tube).Best take to the shop for repair,because part for analog tv are impossible or near impossible to find and do for the replacement.
3helpful
Where are fuses on Toshiba 32a14 TV won't turn on
The fuses are located on the inside of the set, remove the back cover and follow the power cord in, there should be a main ac fuse near the cord on the circuit board. Toshiba usually has a second fuse further up the power supply.
1helpful
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Dead
Put it on the rubbish. Thanks
3answers
Toshiba 32a41 has power, no pic or sound
please clarify it are you getting light? power button will not turn it off means what.
Top GE Televison & Video Experts
Jaime Hernandez
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
