It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
Well first off put it back where it was originally. if that doesn't fix it you've probabple blown the transformer in the power supply and it will needt o be replaced.
Check plug first the one you plug in wall if there is a small black box at point were you plug in ,there is a transformer in there sometimes they short out .Check with multi meter if it is good then try schematic or Circuit diagram
Is the spindle motor OK? Try turning it with your fingers (POWER OFF). Also try taking the cutter out and rotating the empty collet (POWER ON) with your fingers.
Open the back of the tv check th epower supply for busted/leaking or swollen capacitors - if you have experience solder some new ones in place - use the 105degress one for a longer lasting capacitor - the radio shack ones will work but they are rated at 85 degrees and wont last as long.
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma. (UL) US Ite powuer supply made in japan
If your transformer is fried then you will have to replace it of
course, but if it has only opened the thermal fuse that is tucked into
the primary windings then you can replace that and not have to replace
the entire transformer. Be sure to use the same temperature and
type thermal fuse as the original. You will find the thermal fuse
tucked in where the ac power in wires go into the transformer and you
may have to clear some plastic out of the way in order to get to
it. Be very very carfull that you do not nick or cut or break any
of the magnet wire that makes up the windings of the transformer.
Good luck.
