Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Panasonic pt-50lc13 questions...
Hello every one....I just got a panasonic hdtv modle # pt-50lc13....I got it for free!.....the problem is...the TV will come on for about a min. then shut off.....when it does that the little "lamp" light flashes. Does that mean it needs to be replaced?????? If so...how do I go about getting one that wont cost me a arm and a leg??? Could it be anything else wrong with it???? Its so pretty when it comes on......it just wont stay on. :( Please help. thank you so much!
Anna
Posted by AdreannaLee on
  • Anonymous Nov 11, 2007
    See my question above with the answer. The problem is...these TV's are GARBAGE and Panasonic would not back them up.I am going to have mine looked at. Turn the Tv on then shut it off and the red light will not blink. Panasonic = JUNK
Anonymous
I had mine checked out today with your same problem and the Ballast is bad. The fix is $ 361.00 total Thought you would like to know Good luck
Posted on Nov 15, 2007
Where is the lamp reset button on my panasonic PT-50LC13
To reset the lamp on the Tv you need to Hold down vol - on tv and hit either PIP or SPLIT on remote Good Luck
Nov 12, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13
The ballast probably needs to be repaired. A repair kit #LSUC0022 is available from Panasonic.
Jul 18, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Have panasonic pt -50lc13 tv
Jan 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
107 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
