Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar-501 Code H3-00 - Sharp AR-5316 Advanced Digital Imager Copier
Gift Ntwana
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Heat roller abnormally high
temperThermistor defect
MCU PWB defect
Fusing connector connection failure
Power supply failure
atureCheck the heater lamp blinking
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness. Check the MCU PWB
thermistor input circuit.
When the lamp lights up instead
of blinking:
Check the lamp control circuit of
the power supply PWB and the
MCU PWB.
Clear the trouble with SIM 14
Posted on Apr 20, 2016
5 Related Answers
san3409jl
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
Anonymous
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
Everett Lin
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
Anonymous
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
What is Sharp ar-501 H3-00 code?
temperature
Jun 18, 2014 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Provide tuner ar-507
Hi! You can call Sharp Toner Discount Centre on 866-501-6053 and then place your order on the following link-- http://www.sharpcopiertoner.com/model-AR_507-72.html Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Sharp AR-507 Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Error code Sharp AR-M 257
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 651 SERVICE CALL
what is code nomber please send me
Jan 13, 2009 | Sharp AR-651 Copier
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
100 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
