Enter your BIOS and look under Boot, Boot Sequence, or Boot Settings. You can see the BIOS entry key when your computer boots. Typically, its F2 or the delete key as soon as you see the title screen. You can change the sequence as needed. You can also do a one time boot if it is enabled. That key may be F10 or F12.
SOURCE: what is the boot order for acer aspire 7741
To use the Acer recovery CD you need to boot up with the CD.
Go into the BIOS setting and scroll through the settings until you come to Boot order. Then move the CD/DVD drive up as the first boot device and the hard disk as the 2nd boot device.
When you boot up the Acer with the recovery CD in the CD/DVD drive then it will boot up with the Recovery CD.
