I am rotating between error 30, error 50 and error 70. Help me clear these errors. There seems to be ways to code clear them, but where oh
This video maybe will help you
How to Reset Purge Counter on Brother DCP 195C or DCP 197C Printer
Resetting the purge counter must fix your problem
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
SOURCE: Brother DCP-135C Error message CLEAN UNABLE 46
The error you are getting is telling you that the
Waste Pads have to get replaced because they are saturated with ink.
The sets of pads run under $20. The Upper set of Pads is not too hard to replace, you need to take the scanner assembly off, upper cover and control panel and the flushing box is in the back. The second pad requires taking out the printer mechansim and platen roller , bottom plate and possible removal of printhead. I do not recommend you doing this.
The unit then needs to get reset.
thanks
SOURCE: Brother DCP-195C Compact Colour Inkjet ... i have
Brother DCP-195C Compact Colour Inkjet error unable clean 46
SOURCE: error 50 brother dcp 130 d
on my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
