Brother DCP-7065DN Multifunction Laser Printer Logo
A
Anonymous Posted on Jun 18, 2014
How to reset unable to print 36 in dcp 7065dn
Lukas Menelaou
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Brother Expert 234 Answers
  • Posted on Aug 01, 2014
Lukas Menelaou
Brother Expert
Level 2:
New Friend:
Greenhorn:
Answers
234
Questions
0
Helped
45994
Points
249
Unspecified Error. Most likely MAIN PCB
BROTHER DCP-7065DN HOW TO REPAIR LEFT SIDE VERY LIGHT PRINTING
When this occurs it usually means that the toner cartridge is running out of toner on that side. The left is most common since most printing is on that side. Remove the toner cartridge, and shake it vigorously from side to side for a few second, then replace and try again..
71 print unable error
Clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip behind the printer head
Brother dcp 7065dn are problems print unable EF
Check the ventilation fan on the side. Might not be working. Remove any foreign material blocking the fan.
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
How to configure Brother DCP-7065DN to scan directly to Synology DS412+
I don't believe the DCP-7065DN allows scan to FTP. Brother's models MFC-7460DN and MFC-7860DW do provide this function. Good luck and please share your solution should you find one.
2helpful
Print unable 36
hellow body print unable 36 problem is a logical card problem
Change this the problem is over. Thank U
Stuck at "please wait"
If you go into the main menu you will find an option to set all parameters back to "Factory Default" I would start there. Then check for any updates online.
1helpful
I HAVE DCP 7065DN IT SHOW ME TONER ENDED WOULD U TELL ME WHAT CAN I DO
Norman Weimar
Norman Weimar
k24674
