Security light won't go off so iron isn't heating up how do i switch it off as the iron isn't functioning at all ? this has only happened recently
SOURCE: red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
SOURCE: the auto stp security light is on and the iron
i'm not quite sure what the STP security light is but on my iron a security light comes on when the iron is idle. It shuts the power to the iron when no movement has happened mine is about 5 mins.
SOURCE: Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
SOURCE: Tefal program 8 500 Iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
God bless you
