Question about Hobart HL600 Legacy Stand Mixer
Hod do you change the fuse on a Jenn Air mixer?
Where is the jenn air mixer thermal cut out
Wonder if you checked the user manual on possible causes for not turning on. see page 10.
http://content.abt.com/documents/5384/JennAir-Mixer
Aug 13, 2014 | Jenn-Air Attrezzi JSM900 Stand Mixer
JennAir Attrezzi dead, no light, no nothing. Was working. What do I need to do?
Replace the fuse located below the plug inlet on the mixer, you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Oct 11, 2011 | Jenn-Air Attrezzi JSM900 Stand Mixer
Mixer stopped turning while kneading dough. My guess is it blew a fuse?
Yes could be ..check the fuse in the plug first , then see if a Thermal cut off has taken place if so reset this ,if still dead then chance is the motor has gone , which is quite expensive to fix, you may be better with new machine....Good luck...
Feb 19, 2011 | Jenn-Air Attrezzi JSM900 Stand Mixer
It just stopped during use and seems completely dead!
Replace the fuse located below the plug inlet on the mixer,(it is a 6.3A Fuse, 250V 5x20MM fuse from Radioshack) you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Aug 11, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
We was mixing doug for tamales and quit working i unplug it for 30 min and plugit again and didnt work
You could have actually overtaxed the motor. Try plugging it in at a different plug. if it still won't work you may have caused the motor to burn out. You may want to contact the manufadturer .
http://www.jenn-air.ca/en/CustomerCare/Support_Options.html
Dec 21, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
Hi i just had my mixer spark and then the motor
Could be carbon brushes, switch it's really hard to call it,
Let us know how we can help you
Nov 25, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
Manuel
Here is a website for your Jenn-Air Mixer User's Guide:
http://www.allbrands.com/misc_files/pdfs/Mixer_User_Guide.pdf
Click on it take you to a User Guide in PDF format.
May 05, 2008 | Jenn-Air Attrezzi JSM900 Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
149 people viewed this question
Top Hobart Food Mixers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Lawrence Oravetz
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
