You'll have to find the source of the leak to find out what went bad. It almost sound like a line going to the transmission cooler, but you could have a hole in the transmission casing. See if you can put it on a jack and figure out where it's leaking from.
first unlock latches locate up on roof under the sunvisors.
then roof switch located on center consoul just before the shifter. back to you to open, and forward to close.
if that dont work then check fuse
if not that check wiring.
if not that then its the motor.
