Bose 901 VI Main / Stereo Speaker Logo
A
Anonymous Posted on Jun 17, 2014
Bose 901 equilizer connections to sansui G901DB
I've been trying to connect two set of Bose 901's to Sansui G901 I must have the connections wrong because the system sound super tinny
Scuromondo
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jun 18, 2014
Scuromondo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1948
Points
It sounds like you may have only the 901 loudspeakers, and not also the companion 901 equalizer box. You must install the 901 equalizer properly--using the tape monitor loop of the G901 receiver. If you of not, the 901 loudspeakers will perform poorly.
  • Scuromondo Jun 18, 2014
    Also make sure the speaker connections to the receiver are phased properly: (+) to (+), and (-) to (-). Failure to do that will also cause speakers to sound weak.
Don Wallis
Level 2:
Scholar:
New Friend:
  • Expert 67 Answers
  • Posted on Jun 19, 2014
Don Wallis
Expert
Level 2:
Scholar:
New Friend:
Answers
67
Questions
0
Helped
21875
Points
116
Hi. Sounds like the EQ is either not functioning correctly or you have made an incorrect connection. Broadly speaking the EQ will accept a normal line level signal from your amplifier (Line Out, Tape Out or Pre Out/Main In) and will change the response curve of the sound to suit the 901s. The signal is then routed back into your amplifier's power amplifier and finally to the speaker input terminals on the 901s. Be sure to choose the correct switch position on the EQ depending on how you use it. Here is a link that explains the setup clearly with diagrams. Hope this helps.,
Don.
http://worldwide.bose.com/axa/assets/pdf/owner_guides/StereoSpeakers/901vi_guide.pdf
2 Related Answers
Anonymous
  • 9 Answers
  • Posted on Jul 08, 2009
SOURCE: How to connect old 901 Bose equilizer to amp/receiver
If you plan to use them with a home theater, you will need a seperate amplifier, as most a/v receivers don't have tape monitors. With an integrated amp hook rec out to the input on eq hook output on eq to playback on tape mon. with seperates hook pre amp out to input on eq, output on eq to power amp input.
Anonymous
  • 8546 Answers
  • Posted on Aug 04, 2010
SOURCE: trying to hook up bose 901 v to sansui 8080db is
Just remove the Pre-Out to Main In jumpers and connect the Active Equalizer there. This way it will affect only the power output to the amp and speakers but not to any of the Tape Loops. If you need more, look around on Fixya for 901 advice and you'll find about a million posts by me for many scenarios, including multi-channel.
Bose 901 equalizer connect to Lafayette 3500 receiver using bose 901 speakers
The Bose 901 speakers require the use of a specific equalizer that is designed to optimize their performance. If you have a Bose 901 equalizer, you will need to connect it to your Lafayette 3500 receiver in order to properly use the speakers.
Here are the general steps for connecting the Bose 901 equalizer to your Lafayette 3500 receiver:
  1. First, ensure that the power is turned off on both the receiver and the equalizer.
  2. Locate the preamp output jacks on your Lafayette 3500 receiver. These will typically be labeled as "pre out" or "line out".
  3. Connect a pair of RCA cables from the preamp output jacks on your receiver to the input jacks on your Bose 901 equalizer. These jacks are typically labeled as "preamp in" or "line in".
  4. Next, connect another pair of RCA cables from the output jacks on your Bose 901 equalizer to the main amplifier input jacks on your receiver. These jacks are typically labeled as "main in".
  5. Turn on your receiver and equalizer, and ensure that the volume levels are set to a low level before playing any music.
  6. Set the Bose 901 equalizer to the "On" position, and adjust the various equalizer controls to your preferred settings.
  7. Finally, play some music and adjust the volume levels as needed. You should notice a significant improvement in the sound quality of your Bose 901 speakers with the equalizer properly connected.
Note: It's important to use the Bose 901 equalizer specifically designed for the speakers. Using a different equalizer or not using any equalizer at all may result in poor sound quality or damage to the speakers.
Bose 901's
yaa you can use its best idea but i think you cannot integrate the equilizer into the amplifier settings! it will not give as much effect as you want!
I just connected two sets of 901'a to Sansui G901 receiver. The sound is TINNY no bass at all. I've tried different connections and nothing seems to work. I've used two different EQ from bosse series
Either there is NO bass on the recordings (if you listen to it with headphones does it have bass?) ...OR...you've wired them out of phase. Connect only one(1) Bose 901's to just one side. Is there bass? Then connect the other side. IS there bass? If not reverse the phase (+ /- connections) and see if the bass comes back. Once that is done and there is BASS, then add the 3rd and then the 4th speaker. .Are you sure your Sansui can handle a lower than 4 ohm load???
Sansui hdlcdvd26s
see the diagram attached, you can have wrong connection. However clean the contacts and test the wires.God bless you
he speakers are not connected properly. Check the speaker connections. The sound level on the rear or center speakers is turned down. Adjust the sound levels. The receiver is not in the proper surround mode. Set the receiver to a surround mode. The speaker settings are incorrect. Check the settings as per the user's manual.41a9b9c6-64e2-4745-adf3-95fdac1fe686.jpgba7a1620-dfc0-4e45-8fea-6237135735f9.jpeg
Screeching sound from Bose 901 Equalizer
Check the treble on the EQ, is it possible to take a pic of the equalizer?
1helpful
How do i connect 901 Seriees VI Equilizer to a Yamaha HTR-5790 AV Receiver
Let's try this for a third time. Bose AMP OUT to Yamaha MD/TAPE IN.
Bose AMP IN to Yamaha MD/TAPE OUT.
Please rate this solution.
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
2helpful
Trying to hook up bose 901 v to sansui 8080db is
2answers
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
