I insert the tape and it immediately is ejected, with the tape stuck on a pin of some sort. I can lift the tape up and then remove the cassette or if I just pull it out, the tape tears
SOURCE: DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
SOURCE: power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
