The camera wont focus when you turn it on and cmes up with an code E:61:00
SOURCE: error code C:31:42 on a Sony Digital Handycam DCR-TRV530
C:31:42 shows following error..
FG fault during normal drum operations.
Its related to drum assembly (video head) in camcorder and possible reason can be drum stuck with some thing, no power to drum motor etc.
SOURCE: my sony digital handycam flashes C:31:42
C:31:42 indicates that you having a problem with capstan motor. It has to be replaced.
Testimonial: " C:31:42 indicates that you having a problem with capstan motor. It has to be replaced. Is it worth repairing and if it is where ? Thanks"
SOURCE: Hi i got a sony handycam with C:32:11 error. Cant
YEs,
check this
http://www.youtube.com/watch?v=VUIN-ygjN_g
SOURCE: Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
SOURCE: error code E:31:00
The solution is very simple if your camera has a memory stick slot! For those who has any Sony camera with memory stick slot, try this:
1- Place the memory stick
2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.
3- Go to "Manage Media" again, then to "Format Media", so choose to format the HDD! - Now that you are running the camera from memory stick, you'll not have any problem to format the HD.
At least worked with me! I think it worths the try!
