Question about Whirlwind FH-778 Air Conditioner
How do I add freon
Can I add Freon to this unit without adding valves, or are the valves already there?
5 Related Answers
Anonymous
  • 28 Answers
SOURCE: adding freon to my central air
Well duprees, first you got to have the right instrumentation for charge freon to a a/c system, now, the charge line is the thick line, wich it means the suction line, the colder line, or the most robust line on the compressor.
Then, the system uses freon 22, the right charge, with the system on and the compressor running is 68.5 to 70 psi.
This should give to you about 40 degrees(farenheit) at the evaporator, the panel that gets cold in the system.
This pressure should be at the low side, meaning thicker line in the compressor unit.
Hope this help you......
Good luck.......
Posted on Aug 15, 2008
Anonymous
  • 540 Answers
SOURCE: freon
Go to the supply house and ask for an in-line tap! SSSSSSSSSShhhhhhhhhh(the mechanic might had connected the wrong end of the hose,(one end has a hole and the other end has a valve stem depresser to depress the valve stem to let in-out freon.. Or the older type, you have a king valve and has to be turned to open or close the ports!) ssssshhhhhhhhh!!
Posted on Sep 01, 2008
taran_2005
taran_2005
  • 10515 Answers
SOURCE: how do I add freon to my window air conditioning
My advise call a tech.
EPA performs random inspections in response to citizen tips pursuing potential cases against violators. The EPA is authorized to assess fines of up to $32,500 per day for any violation of the Clean Act regulations.
Always take a wise decision.
Thanks.
Posted on Jun 25, 2009
Anonymous
  • 614 Answers
SOURCE: What are the settings for R22 on an older 2 ton
Sustion or low pressure depending on indoor temp about 70-75 head pressure will vary with a,bient temp. But no moe than 260 to 275. Rus
Posted on Jul 15, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: who to added R22 freon to my a/c condenser unit
why would you need to add refrigerant ?
If you need to ask which hose goes where,you are not qualified.
Posted on Apr 06, 2010
How can I bleed freon on my 2007 Impala LTZ
there's no way to legally take Freon out without a machine but if you push down on the valve with something some Freon will come out
Jul 01, 2013 | Cars & Trucks
How do you add freon to haier window unit air conditioner
Window units do not come with service ports. You can buy them at local parts houses, but unless you have the freon, not gonna do you any good. Window ac use either r22 our 410a, and that cannot be bout without being certified.
Aug 18, 2012 | Haier Heating & Cooling
How do I add freon to my ac compressor?
unless you are licensed to handle freon don't. there are some big fines for releasing freon. also if you are not experienced there are safety concerns!!! Is this a home hvac or car? Now with that said you have to add it on the suction side of the compressor.You will need to know the correct type of freon that goes in your unit which can be found on a tag on the unit. You will also need a set of ref. gages to monitor the low and high pressure sides of the unit. it also needs to be added to the outside unit service ports (Home). You need a set of ref scales so you know how much ref is being added. Too much ref and you start pumping liquid. Too little ref and it doesn't cool like it should. If its a car you still need the above equipment. still goes in the suction side.If you add to much ref you can lift the safety pressure valve and dump the freon in the car system. Each type of ref has a pressure you want to see on the suction side and hp side. since they differ with each type ref. you will have to look it up possibly on the internet. If suction pressure goes below 32 degrees you may freeze any condensate the unit makes and have another problem. Hope this helps you but its not as simple as hooking up a ref cylinder and just adding freon. their are many thing that can go wrong and damage equipment or hurt yourself.safety is the first priority.
Jul 07, 2011 | Air Tools & Compressors
Need to add 'freon' to my samsung window unit.
Hello, in order to add freon to a window unit you must add a piercing valve to then low side of the system. The valve mounts to the suction line and allows you to connect your gauges and add freon. Here is a link to where you can purchase piering valves. http://www.hvacr-tools.com/mm5/merchant.mvc?Screen=PROD&Store_Code=HVACR&Product_Code=BPV31&Category_Code=VALVES
May 30, 2011 | Samsung Heating & Cooling
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
Can freon be added to an under the counter unit?
Freon can be added to any unit, but you e going to have to take the unit out to exposed the back where the component are located. Why do you think that you need freon. Unless the line was punctured. it unlikely that you would need to add freon, Is it not getting/keeping cold. Problem might lie elsewhere like in the thermostat. Hope this helps.
Feb 09, 2011 | U-Line 15R Compact Refrigerator
My Amanda wall unit keeps freezing up. Cleaned filter and coils, please advise. Thanks, Gilbert
If a AC unit starts to freeze up, then that is a sure sign that it is low on freon. A wall unit is harder to add freon to since those units generally do not have Shrader valves to purge or add freon. It is sort of like your refridgerator in that the freon is sealed in the factory and to add , a technician has to cut the evaporator tube and add a valve, then add freon, pinch the tube off and seal it once the correct pressure is adjusted.
I would say that somehow your unit has developed a leak, and will get worse.
see:http://real-estate-agents.com/tips/hvac/maintain-air-conditioner/
Jan 23, 2011 | Amana PTC123B35AE Air Conditioner
How to add freon?leak fixed but can find the nipple to add freon.
there is no nipple to add freon, but there is a service valve.. this is a sealed system, only someone with their lic should be adding refrigerant
Oct 02, 2009 | Refrigerators
How do you add coolant to a goldstar air conditioner
There are two lines leading into the unit, the high side aND THE LOW SIDE. tO ADD FREON you need to add a valve to the low side line. But if you have a leak that indicates that moisture is in the unit and you need to pull a valum to remove the moisture before ADDING ANY FREON. There are as last known three types of freon, R22, R134a and this last one I dont even know the name.
Sep 08, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Paul Carew
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
