Radio Communications Logo
Question about Radio Communications
What is this? my Icom IC-F4029SDR displays 'sorry'
ka4iup
  • 4,062 Answers
It appears that the radio has been locked out from service. Return it to whom you got it from.
From pg 35 of the manual:
D D Stun and Revive
The dispatcher can send MDC 1200 signals that will stun or
revive your transceiver. If a Stun command is received that
matches your station ID, the transceiver will display "SORRY"
and you can not receive or transmit. When a Revive com-
mand is received that matches your station ID, normal operation is restored.
Posted on Aug 02, 2014
3 Related Answers
Anonymous
SOURCE: icom IC-F1020 and icom ic-f3
cqham.ru
Posted on Apr 13, 2008
Anonymous
  • 2761 Answers
SOURCE: combine
You can follow the link below for a complete listing of FRS/GMRS frequencies.
http://www.walkie-talkie-watch.com/frs-gmrs-frequency.html
Bill B
Posted on May 12, 2010
Anonymous
  • 607 Answers
SOURCE: icom ic-r70 display
Hi Gary,
to give you the best advice and all the info you require, may i suggest you join yahoo group SPECIFIC to your radio Make/Model, the techs, there will give you all the info you need, but describe the problem fully, don't be afraid to give as much info regarding your radio as you can, the more you ask, the quicker the solution to your problem, you can download manuals, schematics, and other goodies for your radio and all is free.
Best regards,
Peter
Posted on Mar 06, 2013
I have an Icom IC R-71a and i have just turned it on and the numbers in the frequency display do not move, i can not tune the receiver.
https://www.icom.co.jp/world/support/download/manual/disp_down.php?GNR=Receiver&TYPE=Base%20Station&PDNM=IC-R71A/IC-R71E/IC-R71D
Can I use an Icom AT-180 ATU with my ICOM IC-7300 HF radio
AT-180 ATU is not intended for IC-7300. Icom IC-7300 have a built-in tuner already. maybe you can use a special cable or interface to use the AT-180 on IC-7300.
I want to know how to do hard reset on the ICOM IC-M802. Thanks.
The link below should help you. Lots of info in the service manual. It's intended to let someone rebuild the radio from the ground up.
The radio has been locked out of service by the owner. Return it to get it unlocked:
Pg 35 of the manual:
D D Stun and Revive
mand is received that matches your station ID, normal opera-
tion is restored.
Display has stripes
This is a typical failure mode for this rig. The only repair is to replace the display. Check with Icom, I think they still stock the proII displays, if not, out of a scrap radio is your only hope
OVER V error ON ICOM IC-A24 when power UP ?
Sorry to say, but normal. As long as radio works fine otherwise don't worry about the error display.
How to add frequencies/channels to ICOM IC-F21 two-way radios?
Sorry, but your radio is limited to 16 channels in the 400-430 and 440-470 MHz ranges. The number of channels cannot be expanded, nor can the frequency coverage.
Bill B
2answers
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
