Alesis M1-Active MkII Main / Stereo Speaker Logo
Question about Alesis M1-Active MkII Main / Stereo Speaker
Red light when turning it on
When i turn on my Alesis iM1 Active 520 USBs, the light that is supposed to be blue is just red and both speakers make a thump noise. The same thing happens with no input connected. I found a solution on the internet but my power supply board looks significantly different than the one in the video.
1 Related Answer
Anonymous
SOURCE: Alesis m1 active 520 when powered up the blue
I I have the same problem. I do not see any visible damage with the power supply and am assuming it's somewhere else. I am talking to Alesis but don't yet know what I'll end up having to do. Have you solved the issue?
Posted on Dec 13, 2011
Alesis 620 M1 active no power no light
You just fix the power supply and Brige and check the transformer
Alesis m1 active 520 when powered up the blue indicator light turns red with no input in it.
Hi one of my alesis m1 520 speakers has a fault . it powers up ok but theres hardly any sound coming out . you can hear it but its very low
Try reversing cables between speakers just to make sure it's not cable or source. If it is a bad soaker, you'll need to contact Alesis for a local service center near you. Check w/ Guitar Center also, they have access to service.
Alesis M1 Active MKII Don't get power / Blue light is off
Sure they don't have power? Light breaks all the time on those things. If no power still, open it up and find out if there are any loose connections from the power leads. Bad power cable?
Blue led problem in alesis mk1 active
I dont think its anything to worry about, if the unit didnt turn on at all or the LED flickered then you would need a capacitor or 2 changing; check here; http://www.neufeld.newton.ks.us/electronics/?p=232
17helpful
2answers
I have a plantronics 520,
Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
1helpful
2answers
ALESIS M1 ACTIVE MK2 CONE VIBRATION!
Hello!
my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
help!
Please help me!
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
