Your password is incorrect, Maybe the account you are trying to log on to is incorrect. It is possible that the SAM hive is corrupt. Check caps lock. Try an older password.
You can try an NT offline password reset if you have access to that software. For a fee, Vaio should be able to send you the Software disks.
Hi there thanks but yes password is fine because when I get to recovery it ask my password and that do work fine but when I am in recovery it dosn t show factory recovery only image or cd ??? Should I not av factory recovery on HD ???? Then when I log I safe mode password work fine too so I m abit stuck there I thing I catch a virus that why I try factory recovery but won t me let do it grrrrr any suggestion
Hi there thanks but yes password is fine because when I get to recovery it ask my password and that do work fine but when I am in recovery it dosn t show factory recovery only image or cd ??? Should I not av factory recovery on HD ???? Then when I log I safe mode password work fine too so I m abit stuck there I thing I catch a virus that why I try factory recovery but won t me let do it grrrrr any suggestion and can virus corrupt all of that ????!
You can try safe mode with networking, Download Dr Web or malware bytes and try to run it. You may try to create another user account from the control panel and see if that works. There should be a recovery image on your D drive that it is referring too. Make sure you back up everything.
Hi there thanks will try , and how do I find this image on myD? Pls
Thanks will try all that in morning then will let you know can even do a video if don t work and u can see what s going on thanks alot I yes don t av an assist bouton ok thanks
Hi I try all of it an no joy did download dr web and no virus try to create another account won't let me do it all that in safe web mode !
So when I start laptop press f10 goes to edit boot option I get
Edit boot option for windows7
Path :\ windows\system32\ winload.exe
Partition:2
Hard disk: e6085988
[ /NOEXECUTE=OPTIN ]
When press enter go back to loging and same hapen can not logging to my user acount just say won't load ???????? Please need help what to do thanks
SOURCE: to factory reset my samsung v25 laptop
Let me know the password error appears in your window?
SOURCE: Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
SOURCE: Can't restore factory intallations and settings: Vaio VGN-FE880E
Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
SOURCE: Emachine D620. After system restored, password-original factory
install fresh copy of xp on different location of pc and extract files from ealier installed xp
SOURCE: Emachine laptop D620: reset password after system restored
Insert OS cd in drive and start reinstalling by selecting repair mode
now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now
you will come to old screen and previously configured desktop with all
intact aplication and icons on desktop and it will no more ask you for
password till you set a new one
Thanks and regards
Kindly rate this solution
Hi there thanks would try what u say and how I find image on my D
Without knowing the history of the laptop, I can only assume there is a recovery image on your D: Disk. or some other partition.
Add a CommentLaptop has a Hidden partition, to access it with the computer turned off simply press the [Assist] Button, it should turn on the computer and launch the Rescue partition. if that does not work turn on the computer and tap the [F10] key a few times at the VAIO logo a screen that states"Edit Boot Options" will appear simply press enter and the tools will launch once the tools load choose "C Drive Recovery" and everything will be wiped clean back to the original factory image. You can even use Rescue data to try and save any of your files before starting the Format. Once the unit is returned to the original image once you are at the desktop of windows, press [Assist] to open VAIO Care and create a set of recovery software. all you need are 2 blank DVDs
try the above to see if that works. Remember though. Back up important files or pictures before doing this.
