Olympus VG-150 12.0 MP Digital Camera - Silver Logo
B
Barbara Ann Tong Posted on Jun 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i go to view my pictures i have a screen with a white hypenated line square in the middle
Karl Whisenand
Level 3:
Genius:
  • Master 1,554 Answers
  • Posted on Jun 19, 2014
Karl Whisenand
Master
Level 3:
Genius:
Answers
1554
Questions
Helped
752712
Points
4266
Is this what you see on page 14
http://www.camera-usermanual.com/manual01/olympus_vg-150.pdf
y m d time
___ ___ ____ __ __
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
A plate came off the bottom of car i think it is a heat shield of some kind.?
So go to a dealers parts counter
they will show you a picture of it on a
computer screen
White screen with black vertical hypen lines???
Hi, you should get an update for your graphics driver and the Bios update. After the updates for the driver. Do a hard reset. To do a hard reset. We need to shutdown the notebook. Remove the battery. Remove the power cord. Press and hold the power button for 30 seconds. Do not expect the turn on. That would be weird. Actually we are trying to reset something internally. After this. Test if the issue goes away. Hope this helps!
3helpful
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
1helpful
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
No Picture On Screen
change the 33uf 35v at the vertical filter
Thans!
I have a white Verticle line but I get a picture
Have you tried unplugging the sat receiver and plugging it back in? This will reset it.
3answers
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Nopicture
No vertical deflection. Vertical output IC, caps.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
