Question about Nintendo DS Lite
Nintendo ds lite l button doesnt work
L button doesn't work.
Britt Walker
    New Friend:
  • 16 Answers
Does it click when you press it or does it seem to be out of position? If so, that's an easy fit.To fix this you'd have to open up the DS and re position the button and the pin holding it in place.
If not that, its probably got something to do with the trigger inside the DS. When you press the shoulder buttons, they push into a button just below them on the motherboard, which sends a message to the DS. If that has fallen off or started malfunctioning in any way, it could definitely be causing this. You'd have to order one online (link provided to an example) NINTENDO DS LITE BUTTON SWITCH REPAIR PARTS 4 NEW and then solder it in after desoldering the other one, if you know how to do that.
If not, there are probably some repair guys with an ad on your local Craigslist who'd be happy to do it for you for a quick buck.
Posted on Sep 22, 2014
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: my nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Posted on Jan 01, 2008
Anonymous
SOURCE: how do i fix the R button on my Nintendo DS Lite
Take a q tip and wet the end. then you rub the crack between the button and the actual ds the dry it off and blow on it really hard three times
Posted on Apr 28, 2009
mra85008
  • 182 Answers
SOURCE: my nintendo ds lite has water damage
OK FIRST OPEN IT UP AND IF ITS STILL WET PUT IN A BOWL OF DRY RICE FOR 24 HOURS. THE NEXT IT WIL B COMPLETLY DRY. PUT IT TOGETHER AND TRY IT IF IT DNT WORK CHECK THE FUSES. HERE IS A LINK
http://www.m3wiki.com/index.php?title=Nintendo_DS_Lite_:_Repair_a_broken_console_(blown_fuse)
IF UR DS SCREEN ARE MESSED UP GO HERE AND BUY REPACEMENTS FOR IT
http://www.dealextreme.com/products.dx/category.604~r.44989246
Posted on Jul 04, 2009
Anonymous
  • 37 Answers
SOURCE: My nintendo ds lite stopped working but does charge
Battery problem
take out the battery of the ds and then clans it with a wet nap if it still does not work call nintendo they'll repair it for 13.99
Posted on Aug 07, 2009
Zhenya Ogorodnikov
  • 218 Answers
SOURCE: Nintendo DS lite "L" "R" button dont work
OK the buttons are probably dirty. I had this same problem with my DS. Pry open the outside edges of the buttons until there is a gap. Blow into the gap while making sure you dont spit in the console. This should clear out the dirt and make your buttons work.
Posted on Dec 26, 2009
Hi .do you sell Nintendo ds lite for a 8years boy? thanks Doreen Chircop
A Nintendo DS Lite would be a great gift for a young boy looking to play video games. Unfortunately Fixya doesn't isn't an online merchandiser. However, here's a link to a website where you can buy a Nintendo DS Lite.
http://www.gamestop.com/
Sep 08, 2011 | Nintendo DS Lite Console
My nintendo ds lite doesnt turn o. when i plug the
Its a well know fuse problem, you wil lneed to open up your unit and change the fuse close to battery connactions , serach google for location of the fuse , if you are good with electronics its prestty easy but if you r not just take it to repair center Regards
May 05, 2010 | Nintendo DS Lite Console
Dec 26, 2009 | Nintendo DS Lite
Ds mic
My mic doesnt work properly, so i have to get at a certain angle to use it. I have sorta the same problem, so here's my answer. If you play Mario Kart DS, and are plaing the Balloon battle game, get a fan to blow into it. Works every time!
Feb 24, 2009 | Nintendo DS Lite Console
My Nintendo DS lite doesnt turn on
Maybe the baterry doesnt work you could try to buy a new one because at somepoint batteries dont work anymore that happened to me.
Jan 16, 2009 | Nintendo DS Lite Console
The A button doesnt work on nintendo ds lite, is that repairable.
If this is the case then you should dismantle your ds entirely. You have to use a triwing screwdriver which arevery cheap buttttt...
Dec 18, 2008 | Nintendo DS Lite Console
Microphone not working
Yea where IN the DS Lite menu?
Sep 06, 2008 | Nintendo DS Lite Console
My son accidently vomited on his ds lie console and now it doesnt work?
Your DS Lite is more than likely fried. As you may know almost all electronics can survive fresh water encounters, but sadly vomit isn't fresh water. There isn't very much you can do, but pray, and hope it may work one day, or purchase a new Nintendo DS Lite.
Sorry about that.
Jul 29, 2008 | Nintendo DS Lite Console
Nintendo ds lite
you can align it in the options menu. try holding down the power button too it tends to work for alot of consoles and devices
Feb 10, 2008 | Nintendo DS Lite Console
Nintendo DS lite R & L button/ crack in ds
push your button up alot then blow in too it
Dec 15, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
