Question about Sharp AR-5316 Advanced Digital Imager Copier
WHAT IS THE PROBLEM WITH SHARP AR-5620 SL WITH ERROR CODE L1
Gift Ntwana
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Mirror base feed trouble
The mirror home position (MHPS)
does not turn off though the feed
operation is completed during
mirror initial operation after turning
on the power.
does not turn off during shading
operation.
does not turn on when the mirror
base is returned for the specified
time after copy feed is started and
SPF scanning position shift is
performed.
Posted on Apr 21, 2016
5 Related Answers
san3409jl
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
Everett Lin
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
Anonymous
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
Everett Lin
  • 990 Answers
SOURCE: sharp AR-R550n
Hello sir; You may try to perform a reset procedure as follow;
press " program", " * ", " clear ", " * " and start key, then enter 17, press start again, turn machine off and back on.
Posted on Aug 23, 2009
Anonymous
  • 5 Answers
SOURCE: code L1 on a sharp AR-153E digital copier. Any
L1 code means problem with scanner unit. cheque to see if scanner is locked if not , lube rails and ck scanner motor.
Posted on May 23, 2010
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
I need software driver SHARP AR5620 SL
Try Glary utilities (free) I think I noticed they have a way to update drivers
Mar 11, 2015 | Sharp Office Equipment & Supplies
How to Remove Ar-5620 v L1-0 Error
Check the scanning operation with
SIM 1-1.
May 28, 2014 | Sharp AR-5316 Advanced Digital Imager...
My Sharp Ar 5620 sl is showing F2 or 2F Error what will i do to solve the problem
You call Sharp Service. There is no way you could fix the problem even if you were told what the codes mean.
You can find that out when the Technician calls to fix it and give you a either a "guesstimate" or a formal written quotation. Either way you will either have to pay a call-out fee, or if you transport it to them, an inspection and quote preparation fee.
Nothing for nothing in this world......sorry !
Poppa
May 19, 2014 | Sharp AR-5316 Advanced Digital Imager...
PROBLEM WITH SHARP AR-5620 WITH ERROR CODE CH
Hello Sir.
I have trouble with my Sharp AR-5620V copier.
when i switch on my copier it has sound pollution like broken wheel in inner side and not printing
Feb 17, 2014 | Office Equipment & Supplies
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
After installation my sharp ar-m420u copier mx-2300g displays error codes L1-00 and F2-00
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Jan 11, 2011 | Sharp AR-5320 Black and White Copier
Error code L1
YOU EITHER HAVE THE SCANNER LOCKED OR THE SCANNER RAIL [SILVER BAR UNDER GLASS NEEDS TO BE LUBRICATED.
Dec 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
60 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
