1990 GMC Vandura 2500 5.7 Vortex So battery checked good new checked with test light at neutral switch blue wire 14 gage has voltage have not gone any further than this can you help or give me more guidance as to what to check???
If you have checked that battery with a voltmeter then that is a false check as you have to have the battery checked with a load tester . Batteries can have good voltage until you hit the starter then they fail completely. So ensure that the battery is good internally.
Testimonial: "the battery has been load tested and is new"
check the ING fuse or the fusible links near the battery.
would I still get all my dash lights if fuse was gone???
the ING fuse is a heavy fuse to run the ingnition and starter circuits so it would depend on the electrical schematics. TRy and get a wiring diagram of the vehicle and trace where the fault could be.
so van started about 6 times but when I drove it the whippers and radio did not work i turned it off reconnected the remote control starter, try it and it started about 5 times with remote, then did not start again , spayed WD 30 into key slot let it sit for bit, tried to start did not work but whippers and radio did, I am think it could be problem with Ignition switch looking for others input.
