Question about Samsung CLP-500 Laser Printer
Samsung CLX 3305W waste toner cleaning or replacing
3 Related Answers
Anonymous
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
Anonymous
SOURCE: MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
Posted on Jun 15, 2009
Anonymous
SOURCE: my samsung clx 3160fn displays..install/replace
I always take out the tank and remove all the waste toner and reinstall the same tank. Works every time.
Posted on Aug 03, 2010
DoIneed o replace all 4 my tner cartrdges
Hi... No, you don't have to. Use the control panel or driver software to check the levels of each cartridge. Then only replace the one that is empty.
Here is Printer Management software that can help you to get the status and ink levels of your printer:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_HK_EN&CttFileID=5928279&CDCttType=SW&ModelType=N&ModelName=CLX-3305W&VPath=SW/201412/20141223104106567/EPM_V1.05.66.00.exe
Here is a link to the user manual for you:
http://downloadcenter.samsung.com/content/UM/201501/20150112184228345/EN/english.pdf
And the link to the home page of your device if that can help: CLX 3305W SAMSUNG Hong Kong
Hope this helps...
Feb 01, 2015 | Samsung CLX 3305
Why wont my samsung samsung clx-3180 waste toner container read its back in place
There is a small led inside the printer which decides if the tank is in place or not. Clean the lamp and the tank
Aug 14, 2014 | Samsung Clt-407 Toner Refill Chips for...
Replace the wast toner for the samsung clx3175
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and still the message will not go. I have a stack of work to do and am stuck as to what to do next! Help please
Apr 01, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
C406 connection problem
Yes Go To Googl Pl*** store download updated driver i would recommend going to printer and Setting But my briain Does not search for that printer is it discontinued? all i see is cartridges (i Nead more info)that is a toner # ) Printers Fr That Toner Is )CLP-360, CLP-365, CLP-365W, CLX-3300, CLX-3305, CLX-3305FN, CLX-3305FW, CLX-3305W; Xpress: C410FW, C410W, hope it helps Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | Samsung Computers & Internet
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
"Replace/Install Waste Toner Tank" error message
Take aout waste toner tank (vertical handle left of cyan toner cartridge)
remove waste toner. Make shure that transparent windows are clean (light barrier). Replace aund resart printer
Oct 23, 2010 | Samsung CLX 3160fn All-In-One Printer
Replace waste toner container message
Mar 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLP-500 Laser Printer Logo
950 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
