SOURCE: i have a richmond gas hot water heater model
resetting your lock out for richmond power vent
SOURCE: pilot light on water heater goes out frequently
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Testimonial: "thank you. will try these suggestions tomorrow. really appreciate it."
SOURCE: i have a richmond 5v40-36f water heater & when
Do you have a natural gas or propane water heater. You could possibly have a dirty valve which stops the flow of the gas. Has there been a change with the environment of the water heater. Check for the draft and back blow of the available air. If the water heater is over 6 years old maybe it is time to replace the unit. Good Luck
Testimonial: "Thank you for the info..but i thought as long as it doesnt leak it should still be good & it is natural gas...2003 richmond 5v40-36f"
SOURCE: richmond integra system model 6g40-36fi pilot wont light
1) Lockout FV tripped
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
2) Bad gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
