Question about LG LRTP1231W Top Freezer Refrigerator
Why doesn't my fridge stop running? - LG LRTP1231W Top Freezer Refrigerator
Model wrt318fzdb01 wont keep food frozen during cold(below Freezing) weather. What can I do to fix it or is that the way this whirlpool is?
Is unit where there is no heat? Your fridge thermostat measures temperature in the refrigerator section. So if it’s 32 degrees where Fridge is located, then it doesn’t have to run to maintain 35-37 degrees inside fridge section. Thus feeezer doesn’t get cold enough to freeze.
Oct 08, 2018 | Whirlpool Refrigerators
Hi, I have a Lanona HJA6110 American Fridge Freezer. The Freezer works, but the Fridge doesn’t and I get the high temp. Light flashing on the front display panel. Upon opening the Fridge door the fan runs...
Go to Amazon.com or click on this link.
https://www.amazon.com/gp/product/B00W4YG47S/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Supco SM0146B Refrigerator Evaporator Fan Motor, Replaces Samsung DA31-00146B
The fan motor is essentially a universal fit on several brands of refrigerators. you will have to save the wiring from the original fan and attach some terminals for the replacement fan
Aug 07, 2018 | Refrigerators
Fridge doesn`t cool
Return it to the store, especially if less than 30 days old (new)?? If used, it may need freon. Does motor run??
Mar 06, 2014 | Refrigerators
Fridge starts up when plugged in but only runs for 10 seconds then shows an E in the Freezer temp and and F in the Fridge temp. What is wrong?
Let it stand in the on position at least an hour to check it's not going through a self defrost cycle. If the temp display then doesn't change and the compressor doesn't run check you have power to the compressor and condenser fan
Jun 13, 2012 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
G,DAY. my fridge which is a hff518w does not get cold in the fridge compartment, the freezer works well.I have tested the fan on the bench and it works well but it wont run when hooked up to the fridge.I...
I think that now that the timer has been opened it needs to be replaced. However the timer doesn't generally shut of just the fan, it's designed to stop the compressor from running and turn on the electric defroster.
Most of the time that a freezer gets cold and the fridge doesn't means that you either have a bad cooling fan or a blockage from ice. A complete defrost will ensure it's not a clog.
Even bench testing the fan is not a full proof test. Usually when you test the fan its in room temperature air and most people test the fan laying down.
The fan operate on very small bearings which are very sensitive to temperature, so testing a fan outside the fridge, you would need to test it in a cold environment and move the fan in multiple directions.
I would suggest that you purchase both a new timer and a new fan.
These items can be purchased at your local appliance dealer or online at applianceparts.com.
Thanks for your question.
Aug 24, 2011 | Refrigerators
Our electrolux fridge in our motorhome sometimes works and sometimes doesn;t on either electric or gas but works when the engine is running would changing the mains board cure the problem we have had...
Not sure exactly what type of fridge your talking about here, as heading says dometic, your comments say electrolux, but I will say this. If it works good with engine running then I'd be looking at my charging circuits and auxiliary batteries circuit. Look for a battery isolator in the circuit as well.
Jul 31, 2011 | Dometic RM2452 Refrigerator
I have a Frigidaire FRC150FF fridge, the fridge light comes on but the fridge is warm. The frezzer compartment is working fine
How old is the fridge? Can you hear it running?
It could me many things. Could be anything from a dead compressor to a coolant leak.
Did someone change thermostat setting, maybe during a cleaning? There's a knob in the refrigerator section somewhere; see if it's turned to "Off" or to a less-than-cold setting.
If you hear the motor running, but it doesn't get cold, it probably doesn't have any refrigerant to compress. That could be recharged, but modern refrigerators are pretty tight, so that would also indicate a leak. With a leak, it will need recharging again sometime later.
Jul 22, 2011 | Refrigerators
The fridge has completely stopped. There seems to be no power. Is this maybe a fuse thing?
hope your food isn t spoiled ,first of all grab a lamp and plug it into the same socket and if it doesn t light check your breaker second if you know which outlet does work get an extension cord and run that over to fridge and plug it in and see what happens could also be a breaker be careful electricity if the fridge starts your doin good
if not bad fridge sorrry
Aug 10, 2009 | Fisher and Paykel Refrigerators
Maytag MZD2766GEW No Cooling
hi thanks for the question . i would replace the relay and the cap then your sure your good to go. thanks te appliance doc rate me please
Oct 01, 2008 | Maytag MZD2766GES Side by Side...
LG LRTP1231W Top Freezer Refrigerator Logo
111 people viewed this question
Top LG Refrigerators Experts
Michael Thomas
Michael Thomas
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
