Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Wfm3301uc/06 clean out lint
How to respond to "Clean Lint filter" light.
had similar trouble and it can start a FIRE. Try cleaning the vent outside. The shutter doors can be hindered by lint and critters. If cleaning the vent door is not enough, take vent pipes apart and clean them. This should be smooth aluminum pipe not, the corrugated plastic etc.. If this does not cure it, the blower may be clogged or dead inside your machine.
Mar 05, 2018 | Kenmore Dryers
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
My dryer runs and heats but seems like no air is being blown. It should have some sort of a blower correct? Taking 2 cycles to get dry and vent is not clogged, but not sure about lint trap slot.
First, of course, make sure ALL the airways are clear, including the area around the lint filter, and the outside vent - lint likes to stick to the outside vent flap, so make sure you clean that off too, and that it opens and closes freely.
Here's how to get the dryer apart
http://fixitnow.com/wp/2004/03/22/appliance-tip-of-the-day-encore-dryer-disassembly/
There is a blower wheel, but it's powered by the same motor and belt which turns the drum. So if your drum is turning, the blower wheel should be turning, too. If not, you may have to replace the blower wheel. Here a link showing how to do so:
http://fixitnow.com/wp/2010/06/30/replacing-the-blower-wheel-in-a-whirlpool-built-dryer-with-the-lint-filter-in-the-door/
Mar 26, 2011 | Kenmore Dryers
How long should the dryer last? We purchased on 3-12-06 and I dry at least once per day.
Its like saying how long is a piece of string? The reliable running time can be for years "so long as the drier is properly maintained". Ie. cleaning the lint regularly: not overloading the unit. :if anything malfunctions, repair correctly or problems seem to multiply after that and deterioration takes place.
Aug 09, 2010 | Estate TEDX640JQ Electric Dryer
Kenmore 90 Series Washing Machine. Does it have a filter that needs to be cleaned regularly. I owned a maytag previously. It had a center post that collected lint etc. that needed to be cleaned. I...
It's an auto-clean internal lint filter. Lint is trapped from water circulating through the filter during the wash cycle. During the drain cycle it's backwashed and the lint goes down the drain.
Feb 02, 2018 | Kenmore Washing Machines
Code on washer machine
open the washer and look for a small DRAIN MOTOR PUMP , usally this could be clogged with lint and debri . located at the bottom side where the DRAIN HOSE is connected , take it out , clean and remove any debris inside , replace it , and try it again , it should work now . AJ
May 20, 2009 | Washing Machines
Fan doesn't work, blades don't turn
Jump out the switch first that will show which is not working
Dec 21, 2017 | Vornado Standard&Full Size Air Circulator...
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
Lint build-up
remove the lint screen by pulling on it ,around build up scrub w/ brush clean w/ portable vacuum .
Dec 31, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
Top Bosch Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
