Question about Palm Tungsten E2 Handheld
How reset palm oneE2 names and addresses from handheld ONLY Part names and addresses
Posted by saleka on
4 Related Answers
Wizard Prang
Wizard Prang
  • 20 Answers
SOURCE: 'Reset' each time after hotsynching
Do you still have administrative access to your laptop? IIRC there are some problems with using PD with a non-admin account.
I would recommend that you back up the "good" backup data on the Laptop. In PD, Choose Tools/Options, the "Data Directory" entry shows where the data is stored (in a subdirectory that looks like the first six characters of the Palm's User ID)
Posted on Jan 18, 2008
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: Lose data on palm m100
Best way to prevent data loss on palm m100, replacing the battery before it drained completely and replacement must be done in 10 seconds. Another way to prevent keep backup on computer side. You need to use same user profile in order to get previously stored PIM data on computer
Posted on Aug 24, 2009
Anonymous
  • 3 Answers
SOURCE: My Palm Z22 won't turn on. If I do a hard reset
It absolutely won't, you don't have to worry. I've done it several times, and I know I was really nervous at first, but it's fine.
Posted on Jan 01, 2010
ww13
  • 16 Answers
SOURCE: Z22 Handheld: what is the price of palm Z22 handheld...
I have seen them listed on Craigslist.com from $15 to 50. I have seen them online for over $300! I guess it is what the market will bear. If you have one that isn't working, there are parts on ebay that may allow you to keep you own running longer.
Posted on Aug 19, 2010
How erase names and addresses unused from handheld E2
Hi, u will have to do it manually, by clicking on it and holding it, it will give options to choose....
Jun 21, 2014 | Palm Tungsten E2 Handheld
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Need instructions on a hard reset
On your handheld, launch the Prefs application. Under General, select Security.
If the Password box says "Unassigned," tap the box and create a password for your handheld.
Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
On your handheld, hold down the Power button.
While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  1. While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
  2. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  3. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete
Mar 03, 2011 | Palm TX Handheld
How do i fix a zire 21 palm it wont turn on, charge,work nothing
Hello.
From Palm support:
1. Press either the Date Book or Address Book button to see if
you can turn on your handheld that way.
2. Perform a soft reset: Use the tip of an unfolded paper clip
(or similar object without a sharp tip) to gently press the
handheld.
3. Make sure the power adapter is plugged securely into a
working electric outlet and is firmly connected to the
handheld. (If no outlet is available, your handheld can also
be charged through the USB cable, but this takes much
longer.)
Note: Your handheld does not have an indicator light to indicate that your handheld is being charged.
4. Charge for another three full hours.
5. If your handheld now turns on, check the charging-battery icon to ensure that your handheld is being charged. Example:
a. Connect the handheld to an outlet and turn it on.
b. Tap Home .
c. Look for the lightning bolt on the battery icon at the top of the screen.
d. If you do not see the lightning bolt, repeat steps 3 and 4.
Hope this helps.
Nov 03, 2009 | Palm Zire 21 P80730US Handheld
How do I get the old address and name off of it the z22
Ok that is an easy fix. Open up your palm desktop software and click on "tools" which it up in the upper left hand corner of your palm desktop. Click on that and then on "users". From there you will get another box and in there it will show the name that is associated with the PDA. You can delete that name and add the name of your choice.
Best wishes.
Aug 11, 2009 | Palm Z22 Handheld
Palm m515 and new computer
go thru the stylus calibration .. set the clock and/or push next .. then push done .. that will get you back in operation .. click on the "Home" button until you see the "hot sync" icon .. click "hot sync" .. your user name is at the top right corner of that window .. just click "home" again to get out of that window ..
Apr 06, 2009 | Palm m515 Handheld
Feb 13, 2009 | Palm M100
Palm T/X keeps on resetting. I did the hard reset but still the same problem exist. Help please.
You will have to rename the backup folder to backup.old in C:program files/palm/ user name folder, then perform a Hard reset on the device and perform  a HotSync to resolve the issue.
Dec 21, 2008 | Palm TX Handheld
Hot sync calendar from outlook to my palm
In my LifeDrive, my VersaMail set-up wasn't quite right. I had my e-mail address in as "name", rather than "[email protected]". That fixed MY problem. Others (including me) are having trouble keeping the HotSync set to sync Calendar. It keeps going back to "Do Nothing" Go to HotSync in the system tray on your PC, right click, select Custom and see if your Calendar (conduit) is set to 'Do Nothing' as an action. I was able to get it to change and work, but just once (so far!!)
Sep 12, 2005 | Palm Zire 31 Handheld
Sep 11, 2005 | Palm Tungsten T3 Handheld
Palm Tungsten E2 Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
