Question about SanDisk Sansa e250 MP3 Player
Sansa e250 won't turn on
Sansa device will not turn on, no screen activity or menu...dark. the Blue ring around the control button is always on and will not turn off. We thought that maybe it needed to be charged. But the behavior hasn't changed after 8 hours of charging
Posted by Leisha on
  • 16 more comments
  • Anonymous Nov 06, 2007
    My SanDisk Sansa e250 MP3 Player is not working... Only the blue light around the button's on/off
  • Anonymous Nov 22, 2007
    yes i m having the same problem... and now i cant even let my ipod to recovery mod.... pls help
  • Anonymous Nov 29, 2007
    My Sansa had the blue light on and wouldnt go into recovery mode or turn on. So I just unscrewed the back on it and popped the battery out. It was that simple. Turned it on as soon as I put the battery back in and it works great. Amazing how simple technology is and how frustrating it can be to fix them.
    My Sansa e250 MP3 player won't turn on. I charged ot last night and then again this morning and I disconected it from my computer and now it won't turn on. There's no light or screen activity whatsoever! It's irritating me and I don't know what to do! I need my music! Please help!!! thanks.
  • catherizle Dec 03, 2007
    ok i brought my sansa mp3 player like a month ago, i put in my computer 2 charge n i took it out and it kept going on n off and it never came back to its normal screen it keeps going on and off
  • Anonymous Feb 07, 2008
    my sansa now is too slow i do'mt know why?? isn't virus>?
  • Kingrott Feb 08, 2008
    I have the same problem . I have tried just about everything, but nothing works
  • Anonymous Apr 04, 2008
    yea mine does the blue ring of death too. i tore the whole thing apart to find the problem. sansas use daughter cards for memory, but that was on tight. it could be the screen itself. i noticed some hardware build into the ribbon wire that could be used to idientify the screen to the motherboard. mabey its damaged
  • Anonymous Apr 05, 2008
    I got my player THREE DAYS AGO and it doesn't do anything anymore. It was plugged into the computer, but when I tried to delete some files, there was nothing in any of the folders. I thought maybe it was just a weird glitch, so I restarted my computer, but now the computer doesn't even recognize when I plug it in. The solution with holding down the record button didn't help, it still doesn't do anything when I plug it in. Is there anything else I can do??
    when trying to turn it on it says key locked
  • nikki66 Apr 05, 2008
    My sansa won't turn on at all I charged it for a couple of hours and it stop working there is no lights on ot either the on button is not lighting up either what is wrong with my favorite music player i can't go on without it please help!!!!
  • la loka09 Apr 26, 2008
    Sansa device will not turn on, no screen activity or menu...dark. the Blue ring around the control button is always on and will not turn off. We thought that maybe it needed to be charged. But the behavior hasn't changed after 2 hours of charging
  • Anonymous Aug 27, 2008
    Same here where do I go to get it fixed
  • Anonymous Aug 28, 2008
    I charged my sansa for a whole day and i took out the cord. after that it automatically turned off and even though i just charged it it would not turn on. I try plugging it in again and when i do in the corner where there is a charging symbol.. its green so i have no clue whats happening.
    please help!!!
  • Gizmo132 Feb 05, 2009
    one day it just didn't turn on....after 16 months
  • Anonymous Mar 02, 2009
    same here.
    my sansa has doen this SO many times before.
    sometimes it freezes, so i just let the battery waste so in the morning i can use it again.
    but now it doesnt want to turn on ive tried everything!
    i went to so many websites possible.
    Please help!
  • Anonymous Mar 03, 2009
    I KNOW!!!! my sansa was charging fer like three hours and then when i took it out and turned it off it broke or something cuz now it won't turn on. i think i saw how to fix it somewhere b4 but i wasn't paying attention. does anyone know how to help??
  • fajkil May 11, 2010
Anonymous
Okay, heres what you do.
try holding the power slider up for like 30 seconds.
then let it go, then turn it on like usual
it should work fine after that....
Posted on Mar 03, 2009
Anonymous
I'm not sure why, but these things have some sort of lock mechanism other than the "HOLD" button. What you have to do is hold the power button and slide the hold over. That works for mine.
Posted on Nov 30, 2007
Timothy D
  • 626 Answers
This will fix it;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Nov 06, 2007
Anonymous
    Problem Solver:
  • 12 Answers
What you do is hold downt the power button for 15 seconds and it will reset the system. Dont worry, it wont lose your songs.
Posted on Feb 09, 2009
Anonymous
Follow this step-by-step and it will work.
http://fixmysansa.blogspot.com/2008/06/i-do-not-take-any-responsibility-for_22.html
Posted on Mar 19, 2009
Artem Beer
I just let it run out of battery then i charge it and its perfectly fine
Posted on Jun 12, 2008
E250 won't turn on
Try resetting the device by pressing and holding down the Menu button for 15 seconds.
If that does not resolve the issue, then you may need to replace the battery in the device.
Feb 09, 2012 | SanDisk Sansa e250 MP3 Player
Just the blue ring, screen does not turn on
Blue ring faillure could be solved, trying to reset the e250.
How to reset:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Only if the reset action above did not help,
reload and update to the latest firmware.
Installing firmware will erase all data from the player !
  • Step 1: Switch to MSC mode.
How to switch to MSC mode:
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the ( |<< ) button while connecting the device to the PC.
  • Step 2: Update to the latest firmware.
See next site for how to update the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
Follow the information in the link.
The easiest way would be using the automatic Sansa Firmware Updater. Directly to the download Sansa Firmware Updater .
Need more help ? Just post a comment.
Dec 19, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 Menu won't show!!!! please help!!
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I hope that helps. If not, please post a comment with an update to your problem.
Jan 01, 2009 | SanDisk Sansa e250 MP3 Player
Sandisk sansa mp3 player
ok , what you do is you pry off the bottons on the front, then there should be a screw. unscrew it. then youll see the screen thing. there will be two metel circals, one of them is probably dusty, just wipe it off and put every thing back together, the buttons just snap back on.
Aug 31, 2008 | SanDisk Sansa e250 MP3 Player
Please help me
You have the locking button activated. Deactivate the button and it should turn on normal.
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
Frozen on the loading screen
press the menu button on the bottommostlft side,,,and also anyone of the other buttons (say forward button) for quite sometime around 2 minutes (probably less than that)............
then the blue light would be turned off and sansa starts rocking again..
HOLD MENU AND FORWARD BUTTONS TOGETHER....
or as you thought u can let the sansa discharge all its power.
dont open at any cost ,because if its found opened then warranty may be cancelled.
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 Cannot Reformat, Blue Ring Only
Not sure what e200 tool you are referring to.
But this is the one provided by SanDisk;
Best of Luck.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
The Screen Stays black and the ring turns blue and thats it
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
Malfunctioning sansa e250
In case anyone else has this problem, I fixed it. I unscrewed the back and removed the battery, then I put the battery back in, and the sansa performed fine, except that I have to put the songs back on that I was trying to put on the device before.
OR
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Aug 20, 2007 | SanDisk Sansa e250 MP3 Player
It wont read any file
If you just got this sansa, call sansa and send it back to them. you still have a warranty. they may give you some problem if you don't have the reciept bu explain that it is a gift. From what you say, you did what you should have. you can always send it to my company so we cna see what the problem is. Thanks, Connie
Jun 20, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
3,489 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
