Question about Samson SX1200 Amplifier
Do you have the schematics on how to connect the Samson sx1200 with other amps?
What are the other amps and what do you meed by connect. More information is needed if you want help.
Posted on Nov 04, 2014
SOURCE: one side of the amp
Either the channel on your radio is not working. Or the AV cord you are using is not working on one side (reverse the cord and plug it in the opposite you are using now. If it still only works on the one side your cord is good.) Or the final transistor for the channel on that amp might have blown. You could also have a cold soldier joint on or otherwise faulty jack plug. Let me know if this helps you find the issue.
Posted on Mar 07, 2011
SOURCE: How do I connect my
on the mixxer, use the "mix" "L" and "R" outputs. use 1/4 inch instrument cables, and connect the mox L and R to the amp's "channel 1" and "channel 2 inputs". always turn the mixing board on first, and the amp second- when turning off turn off the amp first, and turn off the mixer second. start with the mixer levels at the lowest, with the amp levels about 1/2 to 3/4 up. slowly raise the mixer channels first and then the mixer main volume until you have an adequate volume.
Posted on Mar 09, 2011
SOURCE: My speakers stopped working
Heating of the power
transistor
can be one of the causes.
you may have to take out the complimentary pairs to check.
The pair may take out the drivers and some components along with it.
These may take some time, (troubleshooting)
But have a tech to guide you, if you need to DIY.
Good luck, let us know what you find or needs further assistance.
Posted on Oct 05, 2012
Oct 11, 2014 | Samson SX1200 Amplifier
Jun 16, 2014 | Samson SX1200 Amplifier
Apr 13, 2014 | Yamaha S215V Main / Stereo Speaker
Oct 12, 2012 | Samson SX1200 Amplifier
Oct 02, 2012 | Samson SX1200 Amplifier
Mar 09, 2011 | Samson SX1200 Amplifier
Mar 07, 2011 | Samson SX1200 Amplifier
Jan 12, 2011 | Samson SX1200 Amplifier
Oct 01, 2010 | Samson SX1200 2Channel Amplifier
Sep 24, 2007 | Samson SX1200 Amplifier
119 people viewed this question
