Washing Machines Logo
A
Anonymous Posted on Jun 16, 2014
What is code f64? on frigidare affinity clothes drire mean?
5 Related Answers
Anonymous
  • 156 Answers
  • Posted on Feb 27, 2008
SOURCE: frigidare affinity front load washer
is thse the digital panel if so the control board needs replaced
Anonymous
  • 240 Answers
  • Posted on May 04, 2008
SOURCE: ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
Anonymous
  • 3 Answers
  • Posted on Jan 15, 2009
SOURCE: I am experiencing an error
Clean the cold water filter on the back, then try again. This should work. Mine was doing the same thing and the repairman had no idea what it meant.
Anonymous
  • 39 Answers
  • Posted on Apr 22, 2010
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Anonymous
  • 2605 Answers
  • Posted on Oct 29, 2011
SOURCE: frigidare affinity error code E23
Hello, welcome to FixYa.
I understand you have a Frigidaire Affinity ATF6000 series washer with an error code E23, correct ?
If that is indeed the error code you receive in the display it is potentially bad news unfortunately, as that indicates either loose wire (fingers crossed) or a failed drain pump relay on the control board. This is how it is described in the Frigidaire service tech manual.
Further to this, if it is not a loose wire at the pump or on the control, the only remedy is to replace the control board, unless you are proficient at electronic repairs (including soldering techniques) and can purchase an exact relay and replace just the relay...though that doesn't guarantee the control hasn't suffered collateral damage in the process.
A new control is part #134523106...
it is available at several on-line parts vendors such as "repairclinic.com" or "searspartsdirect.com" to name a couple as these links will provide.
http://www.repairclinic.com/PartDetail/Main-Control-Board/134523106/1191145
http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Washer-Parts/134523106/0026/417/Model-ATF6000ES1/1428/0153200?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=R0604038&diagramPageId=00001&productTypeId=0153200&searchModelNumber=ATF6000ES1&subCompDesc=Control%20panel&brandDesc=FRIGIDAIRE&modelDesc=WASHER&blt=11
Hope this answers your question and helps you move forward. Let me know how you make out or if anything isn't clear. Good luck and thank you for choosing FixYa today.
Regards,
Macmarkus :)
Our dryer runs, however, the three lights at the end of the panel start to flash and it turns off. There is no error code displaying
The 3 lights flashing are the fault code. You will need to check in your owners book or with Frigidaire what the code means. sorry but I don't have any info on these machines.
May 01, 2019 • Dryers
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
1helpful
Dripping water in frigidare. Affinity dryer
I appreciate your post, Joe Ivey!
From the information you have provided your Frigidaire dryer is leaking water inside the tub when clothes are drying. It sounds like your water valve may be leaking. You may want to have a professional technician out to your home to properly diagnosis your dryer this will help to avoid any unnecessary part purchases or future issues. Hopefully this was helpful. -Matt
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
2helpful
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its then you press buttons and it beeps continuosly...
that's a lot of kids... according to the Frigidaire wiring diagram and codes list E68 means a key is stuck or bad board. You can enter function test mode and check which button is at fault. Hope this helps Tim
p.s. here is a thread:
http://forum.appliancepartspros.com/dryer-repair/143380-frigidare-affinity-dryer-e68-error-code.html
Apr 06, 2011 • Dryers
3helpful
Frigidare affinity model # atf6000es won't spin in
sometimes in the bottom right hand corner of the machine there is a little face plate and allows to you unclog foreign material that collect over time.
1helpful
I am experiencing an error code during my wash cycle of E10... I have a frigidare affinity series washer.
2helpful
2answers
Frigidare affinity front load washer
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
