Question about Panasonic CT-36HL43 36" TV
Why is my TV stuck in Standby? doesnt turn on, just beeps and the red light comes back on
What could it be? If i knew what the beep meant then perhaps i could tell which part of the TV isnt working anymore. Very odd, as it suddenly happened when i put it in standby mode today
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: TV off...cant get out of standby mode
Sounds like the connections on the CRT Socket or CRT circuit board. Remove back and check connections.
You could also have buildup on the cathodes of the electron gun (internally) to redimie you must have set in operation and viewing video. Tap the neck of the tube gently while watching for the colors to change until they Stabileize, this is best seen whith the color turned off.
Good Luck
Posted on Feb 12, 2010
Anonymous
  • 7 Answers
SOURCE: I have a panasonic flat screen tv and My standby
the tv tells you there is a technical problem with it.
lots of time this has something to do with the power supply of the tv.
contact a technician to have it fixed.
Posted on Sep 01, 2010
SOURCE: I have a T28PL1.
First, remote the TV's power cord from the wall, wait for about 5mins, plug it back in then try again. If problem persist, then it means your TV is having a power problem....
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on May 02, 2011
Anonymous
  • 158 Answers
SOURCE: When I turn tv on
Check the power supply mainboard if there are inflated electrolytic capacitors, to replace them.
Posted on May 16, 2011
Anonymous
SOURCE: Panasonic TH42PZ85B troubleshooting standby light
Have exactly the same problem. Standby light flashing twice in 1 second then off for 5 seconds but will not switch on. This after switching off on the set following around 1 hour use.
Switched all power to set off for around 30-40 minutes
Posted on Sep 10, 2011
It turns on but nothing comes up on the tv and wont turn back off
This is a problem with your system software. Please follow these steps to fix it :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later and then beep once more and turn back off into standby(red light on) . Release the power button after it has switched itself back off.
Step 3. Again, press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this an then continue to the next step.
Step 5. A menu will load with 6 options. Choose option 3 "Restore File System". Accept whatever the PS3 says and hopefully it will restart as normal.
If option 3 does not work, do the above again and choose option 4, "Rebuild Database". If this does not work as a last resort select option 5, "Restore PS3 System". THIS WILL ERASE ALL DATA ON YOUR DRIVE!!
One of these options will bring your PS3 back to life.
Hope this helps and thank you for using FixYa
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
The component cable is hooked into the tv and its on the right channel but the ps3 doesnt show the display screen
Try the following easy steps :
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Dec 04, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will not turn on. the light comes on then beeps and turns off
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
My ps3 froze and now doesnt show anything on the screen and controller doesnt turn it on. nothing happens
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
I got my new samsung series 5 tv yesterday and had the ps3 working, then it had a green screen and now the tv wont come out of what appears to be standby mode
unplug the tv for 10 mins to let the tv reset then
try video reset
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Im not getting a picture to come in to tv
try video reset
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 startup fails
try removing the hard drive then booting it up then putting it back in and booting up again.
then try holding the power button while the ps3 is in standby (red light) till it beeps,... then beeps again,...then turns red again,....then let go and hold the power button again real fast you should hear beep....then a double beep beep. let go of button and you should see recovery console. choose rebuild file system. it will reboot and go through the rebuild steps. then if it still doesnt work go through the steps of recovery consol again and choose rebuild database.
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
When i turn my ps3 on nuthin would show up on the tv. You can't even hear anything on the tv...it's just blank. Someone please help me..!!!!!!!!
Alright mate, Try these steps...
1. turn on the ps3 so it is in stanby i.e. the red light is on. 2. push and hold down on the red button for as long as it takes to turn the ps3 back off on to standby, you should hear a beep. 3. when it goes back to standby do the same thing again, and this time you will hear one beep (when you pressed it) and two more beeps and it will go back to standby 4. when it is back in standby again, push and hold down the button again, you'll hear the first beep, then three more beeps, and it will go back to standby. 5. do the same again, however when it turns on this time, if done correctly, it should say connect the controller using a usb cable. do this and turn it on. 6. Go through everything it says on screen, 6 options should eventually appear, for me, option 4 did the trick, but i heard option 3 works too, as the other ones do too i presume. 7. the final part is that it will ask you to restore the hard drive etc... just keep pressing the ok button.
if all fails, then phone this number (sony) 0818 365 065. glad to help. let me know.... David.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
My ps3 doesnt work
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
Panasonic CT-36HL43 36" TV Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
