Question about Uniden 5.8GHz Dual Cordless Phone
How to retrieve messages from my Uniden DECT 6.0 Phone
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
Anonymous
  • 5 Answers
SOURCE: retrieve deleted phone message
Find the customer service # for Uniden products and get to tech support.  They may be able to help you retrieve deleted messages.  Since it's digital and not a tape like the old Sony's, you may not be able to retrieve it.
Posted on May 24, 2009
Dave Ellis
  • 84 Answers
SOURCE: How do retrieve erased messages on the Uniden Dect
Sorry to tell you, but you cannot retreive a deleted message. These phones use a flash type memory and once data is erased, it is gone.
Posted on Feb 26, 2010
David Leggett
  • 268 Answers
SOURCE: retrieve deleted messages from uniden cordless phone
After its deleted then its deleted forever. These are not like the old answering machines that all you did was pull the plug and plugged it back into the wall outlet to retrieve old messages was were deleted. When digital you can not do that....Sorry
Posted on Sep 18, 2010
Anonymous
SOURCE: How do I listen to messages on the Uniden Dect 6.0
Uniden Deck 1363-2BK How to get the voice mail working and how to be abe able to make long distance call?
Posted on Nov 22, 2010
Retrieve voicemail message for uniden dect 6.0 using handset
http://www.brandsmartusa.com/pdfs/manuals/20146396.pdf
The above link is the manual. I was looking at pgs 15, 16, and 18. On pg 18 it says there is a default code that will retrieve messages you enter from phone, that's probably it I think. Download is 12.8mb.
Jun 09, 2016 | Uniden DECT 6.0 Cordless Telephone...
Retrieve messages from Uniden digital DECT 6.0 phone
Since you didn't specify the model of your Uniden DECT 6.0 system, please select the model from the list beginning at http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl
Oct 28, 2013 | Uniden DECT 6.0 Cordless Phone ID
Uniden Dect 6 Manual how do you retrieve messages from a remote site?
What model Uniden DECT 6.0 phone/answering machine?
Oct 18, 2013 | Lands Phones
How do I retrieve my messages from another location? I have a Uniden dect 6.0 phone
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jun 17, 2012 | Uniden DECT 6.0 Cordless Phone ID
How to retrieve voicemail messages
Since you didn't specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Nov 24, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do i retrieve messages remotely for the uniden dect 6.0
Since you didn't specify the model of your Uniden DECT 6.0 system, select it from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to download the manual.
Jun 15, 2011 | Uniden DECT 6.0 Cordless Phone
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Uniden dect 6.o
Mar 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
Remote retrieval of messages, uniden dect 6.0 cordless
30 seconds with a search engine got this page http://www.uniden.com/index/manuals_results.cfm?cat=59
Put in your model number and you're good to go.
Carl
Aug 27, 2008 | Uniden Cordless phone EXS9950
Uniden 5.8GHz Dual Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
