If you have a leak, you have your answer. The machine thinks that you are pulling on the trigger, but in fact the water is just leaking out...the poor machine does know the difference.
The problem is probably just the plastic elbow between the pump and the pressure hose. It is designed to fail in cases where a rigid fitting would cause serious damage to the pump head. Failure is usually caused by the machine falling over, being dragged by the high pressure hose or rough handling. Then again, the elbow can just fail. It is designed to do just that
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
SOURCE: Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
SOURCE: Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
SOURCE: We have a Karcher G2500VH pressure washer. If you
Hi, Karcher calls the unloader valve a spill valve,
this is a link to a full drawing/parts listing , and your fault description might well be a sticking /seized unloader(spill ) valve hope this helps
http://www.pressureparts.com/ManualViewPage.aspx?Manual=/mmDEV/PDF/karcherparts/g2500vh.pdf
the part number is on page 9 of the drawing
spill valve 45910400
hope this helps , we usually use some good quality silicone grease to lube the valve ,
SOURCE: My electric Karcher pressure washer does not shut off.
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
